Prestone top-up
1 minute ago, Tech1e said:
Has that been tested?
No, I used to have residual pressure in the header tank overnight and a loss of coolant, so I had it sniffer tested a month ago and then had the head gasket done last week and I think I've still got the above. It's had nothing else done, thanks.
  • Replies 170
  • Views 17.9k
  • No.   Yes, it's the head gasket.
  • There shouldn't be any pressure at all.   Part of the reason this has dragged on so horribly is your denial, we're up against it at every turn in this saga.   You're doing it again
  • There isn't actually anything more effective than water. It is the best coolant there is. Anitfreeze is just that, it stops the water freezing and prevents corrosion but ultimately the cooling is done
Id bypass the EGR cooler coolant hoses and see if that resolves the issue.
Do you mean egr delete?
No, just disconnect the coolant hoses from the cooler and connect them together. Then top coolant back up to the correct level and test.
I wouldn't know where to start on doing that to be honest and none of these garages listen to me.
Thats what needs doing though. Change the head gasket as many times as you like, if the EGR cooler is leaking internally (very common) its still going to pressurise and loose coolant.
Are you saying then that it may of just been the egr cooler in the first place and not HGF?
Certainly a possibility.
Would I still of had combustion gasses in the coolant with just a failed egr cooler then? Surely if the HG was fine the cylinder head wouldn't of needed skimming would it?
Thanks for the info
Edited by Tomjones1995
Yes, exhaust gas leaks into the cooling system.
No, was the head tested for flatness before skimming?
I don't know to be honest. I can try and find out tomorrow. All they said was that the engineering shop had gas tested it and skimmed it about 4-5thou because that's what it needed. No mention of testing for flatness or pressure testing etc which concerns me greatly
Just now, Tomjones1995 said:
I don't know to be honest. I can try and find out tomorrow. All they said was that the engineering shop had gas tested it and skimmed it about 4-5thou because that's what it needed. Whether or not that was the case remains to be seen.
Seeing as you still have the issue then I’d probably say not.
Regardless of checking for flatness though. If it was skimmed it would be flat now though? The HG, cylinder head or block wouldn't be the problem at this stage surely?
I very much doubt it.
Okay, so I'm looking at perhaps either the egr cooler leaking or maybe the block being eroded considering that hadn't been checked?
It won’t be the block.
Okay, so just egr cooler? There's nothing else that I need to look at?
I’d start there.
I would have done done that before the HG.
I’d start there.
Yeah I would have if id of known that could be a possible cause. Is there a way of me checking the egr myself without bypassing it? I will bypass it if I have to but would rather check it another way if possible
Remove it and pressure test.
Okay, for both of those methods I would probably have to take it back to the garage then. Il let them know what you said and hopefully they'l do it.
Thanks for all your help
Just out of curiosity. Where exactly is the egr cooler in the system? Do I just disconnect the egr cooler from the coolant pipes and connect them together? Do I leave the egr valve connected? How long do I leave the egr cooler disconnected for? If it's easy to do, I may do it myself
  • Sponsor
I think the EGR cooler is wrapped around the metal hose that connects the exhaust manifold to the bottom of the EGR valve. Access may not be great.
Sorry I didn't think of this possibility earlier, forgot that BLTs have this extra bit.
Yeah I think I can see it stuffed down just below the egr valve. Don't worry about forgetting, we all make mistakes. It may still be HG issues anyway at this stage. Do you think it's an easy job to bypass the egr cooler? Easy enough for a novice such as myself?
