Does DPF regen if warning lights on?
I've got some warning lights which I think are to do with sticky turbo vanes. Still been driving ok apart from the occasional limp, but today I had the DPF light come on! Haven't seen it for a very long time as I generally do a lot of longer drives.
Is it known that the DPF doesn't regen if there's some faults, or shall I give it more of a chance on the motorway (or is that doing more harm)?
I know on my fathers Vectra it won't regen if any fault codes stored. Pretty sure most cars would be the same
What warning light due to sticky turbo vanes, and who diagnosed that?
You best get your car sorted out, and ask that technician or mechanic what is going on.
Has your car had The Fix?  So new engine management & the Flow Device fitted.
& how many miles has it done from new, and since the Fix if done?
http://skoda.co.uk/dieselinfo
Edited by Offski
In my experience, when the DPF light comes on when you NEED a regen. Driving without doing it will inevitably result in limp mode and a forced region being needed. I would get the other faults checked without continuing to drive and/or ask a main dealer for that info as a matter of urgency.
A forced regen will cost you around the £200 mark so better to check/clear the codes!
In 3 years of owning my Skoda, only once the DPF light came on and that's to do with the fact I've been driving in the city only for like 2 months. When the light is on it requires extra attention possibly it can't regen properly or there's a lot of residue oil ash stuck in the dpf.
