1.4 MPI (6Y) Outside Air Temp Sensor fault
Hello people.
Can someone help with location of the Outside air temp sensor on 6Y 2005 Fabia1.4 16V?
Under the front bumper...
Thanks TMB.
I will check it out today and see if the connection is still in place as we had to remove the front bumper to remove the radiator/condenser assembly for a thorough flush some days back.
Hi TMB.
I found a pair of twisted cables without a connector dangling below the radiator not far from under the Aircon/coolant control unit but the attached sensor has fallen out with no idea what it looks like,
I looped the pair of cabke and got a signal short to ground error in VAG diagnostics so I am sure this is the cable for the outside air temperature.
Yes it is, you just need a new sensor and connector, clumsy reassembly after the rad repair.
Half an hour for you on the naughty step!
@sepulchrave, @LB123 thanks for your support and encouragement.
I will try getting 1 or more of these sensors from salvaged item sellers as I cannot get the new units to buy here in Lagos for Skoda sensors.
I also noticed the same sensor was gone from another Fabia that we have. Those sensors are endangered parts considering their location and I am considering relocating them to a safer place well above the front bumper where they will just as well pickup the true outside air temperature.
