Oil top up 1 litre
I need to do a top up on my 1.4 TDS pd engine
there are so many on opine oils I am not sure which to choose
the service I got in may just said do oil
can you fellows help please
cheers
geof
Any oil that meets vw specification 507.00 or 505.01  will do.
Do not use 505.00 spec oil under any circumstances.
Oilman can advise further about oils from Opie oils
Edited by xman
Thanks...I have been coming onto the same warnings on older posts but needed to really get it clear in my head.
dont know really what’s in the engine except the description DP...which covers me
the garage I go to has serviced this car before I bought it..that’s 2 years now.
 I can wait till Oilman checks in.  The level isn’t quite on the low end of the dipstick cross hatching and only recently showed a slight change in level..4000 miles
I will be going up to Bristol soon.. 330 miles total.. so I want to set off with a top up in place.
no use having a max mark unless one uses it...coolant and tyre pressures!
cheers and thanks again
geof
Ps edit.  Opies have an offer on Castrol edge 10/30 and 10/40
i got those results from 507 and 505.01
is it better on my 80k engine to use the 10/40?
geof
Edited by mrcrow
  • Sponsor
geof
geof
Hi Geof,
As already mentioned to top up with on a pd the oil will need to meet either VW507.00 (usually 5w-3) and VW505.01 (usually 5w-40). Make sure it has either of these specs on the bottle. You can get some from me or if you are in a hurry you can find oils on t4he shelf all over the place. I always recommend going for a reputable brand.
Castrol do not do an Edge 10w-30 or 10w-40?
Cheers,
Guy
Thanks and you are right
Went to opies and bought a litre of 5/40 505.01 at £10.
Now I feel more secure with all the info from here and the chap at opies went through all the vw PD oils with me to make sure I got the right ones.
They did have 540/570 which was 5/30 but my last service sheet at the garage showed an oil fill with 10/40 PD oii.
My fabia is on 88000 and I thought the 40 was consistent enough to chose for an older engine.  I shall probably only add around 100 ml to top up and last till next May when the service and MOT is due.
I may then see if the garage will use the Castrol 505.01 and I can buy it for them, or they do it, should be some left over then.
GEOF
Forgot to mention 10% discount at Opie Oils for Briskoda members! Use voucher code BRISKODA
  • Sponsor
Thanks for the order Geof, did you get your 10% discount?
Cheers,
Guy
your shopping with the right guys so half way there before you even order :clap:
Cheers,
Guy
wow...i didnt even know about it...:notme:
the item is listed as £10.99 and the chap charged me £10.00
so i guess i did get a discount...
next time i will quote the "briskoda" password..;).. or code?...i have an opie oil about 10 miles from me...that should work as well?
in the past i have bought bilt hamber clay and speedwax iirc...never bought oil though...would they attract a discount?
i have used the club code for powerenhancer archoil treatments 6900 and 6400 thanks to the chaps here
thanks again oilman
cheers
geof
ps opie oils have indicated that the code...briskoda has expired...??
Edited by mrcrow
thanks....
just touching the edge of self servicing but i am due an air filter and fuel filter in May 2019...the cabin filter is going well after 18 months..self fitted of course.
cheers
geof
  • Sponsor
thanks again oilman
cheers
geof
The code had expired, I do not know why it was not updated. Anyway, all good now the BRISKODA code works just fine.
Cheers,
Guy
Cheers,
Guy
thanks...
you must think me pretty dim...i thought opie oils on the internet was somewhere different from treleigh/mount ambrose...:sleepy:
next time i am in i will give you a personal thanks
cheers
geof
Edited by mrcrow
  • Sponsor
Hi Geof,
I did not realise you were in Hayle, just down the road. Pop in for your oil next time and I will do you a deal.
Cheers,
Guy
3 hours ago, oilman said:
Hi Geof,
Cheers,
Guy
very kind of you Guy
will contact you when i next need to make a purchase
cheers
geof
