Installation help - Skoda Roomster 2006 and Desay RCD330G Plus 6RD035187A
Hello all, i need help.
I replaced Skoda Dance radio, in my Skoda Roomster 2006, for purchased Desay RCD330G Plus (6RD035187A), and now i have strange behavior:
1) Sometimes i cannot turn on radio, when i push the power button, radio not respond or buttons start blinking at random period, without bootup
2) When i lucky, and radio start (most often when I press the power-on when the buttons are flashing), i have two messages on radio:
a) To use bluetooth, please switch on the ignition. (When i try turn on bluetooth)
b) 12V battery almost drained. Switching off infotaiment system. (At random intervals)
Local seller offer me this canbus converter from Skoda, to convert canbus 1.6 in car, to 2.0 thats support the radio, to solve all problems: https://www.skoda-parts.com/spare-part/5j0035751-relay-487-skoda-24938.html
Will you solve these problems?
Thanks for any advice.
* Sorry for my english.
Have you seen this guide?
Yes, i used it, and solve it most of problems, but some new has discovered.
- Turning on/off works OK
- Canbus also work OK (radio read temperature from Climatronic)
But steering whell control and maxidot work only sometimes, and when i check with VCDS, i have this errors:
Address 16: Steering wheel
16350 - Control Module - Self-Test Error
            014 - Defective - Intermittent
Address 17: Instruments
01304 - Radio
            49-00 - No Communications
And address 56 (radio), is not responding
16350 - Control Module - Self-Test Error 014 - Defective - Intermittent
Disappeared after cleaning errors, but second is stay.
