Cruise control not working after mfsw retrofit
Hi all, I retrofitted a mfsw to my pre fl octi and all was well, but I cannot get the cruise control to work despite playing with coding etc.
I keep getting the code below that tells me the stalk is defective, it was working fine until the fit. Here is an autoscan....
Any help welcomed, and thanks in advance for anyone who can shed some light on this issue! Cheers!!!
Log-VO56XDB-TMBGE21Z572032773-415360km-258092mi.txt
Take it apart and clean the contacts, 5 minute job.
My cruise control was working fine (after contact cleaning) until I fitted a remapped ECU this week, it needed coding for the function, working again now.
I'll try it, but it is something I use everyday and had no issues with it until the mfsw fit, then it just pinged up the fault code of it being defective. Also the mfsw I fitted is exactly the same octi 2 wheel but with buttons and the two buttons to the far left are for the cruise control aren't they, originally? Correct me if I am wrong.
Sorry but I have no experience of a MFSW and like so many acronyms on this forum I have no idea what one is or what it means.
@J.R. - MFSW = Multi Function Steering Wheel ;)
@wig - have you got an autoscan from before you fitted the MFSW and a picture of which wheel you've fitted?
I don't Langers, but I know all the faults that were present prior to the swap, and cruise control was not one of them if that's what you were thinking?
Cheers!
Found this in the archive here on Briskoda pre-swap! Hope it helps!
Tuesday,31,July,2018,13:34:14:41824
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.1.2 (x64)
Data version: 20180518 DS287.1
www.Ross-Tech.com
Dealer/Shop Name: MotorServ
Workshop Code: 123 12345 012345
VIN: TMBGE21Z572032773   License Plate: 56WG
Mileage: 410140km-254849mi   Repair Order:
Chassis Type: 1Z (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: TMBGE21Z572032773   Mileage: 410140km-254849miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Not registered 0001
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 021 LD    HW: 03G 906 021 LD
   Component: R4 2,0L EDC G200SG  8514
   Revision: --H02---    Serial number: SKZ7Z0F3727947
   Coding: 0000072
   Shop #: WSC 12345 123 12345
   VCID: 6CD7E8FD4F289724EB-8038
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   Shop #: WSC 73430 790 00000
   VCID: 3F8D6FB16EDEDCBC1E-806A
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 H
   Component: ClimatronicPQ35 084 0305
   Shop #: WSC 00000 000 00000
   VCID: 3B751BA17AC6C09C32-806E
1 Fault Found:
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000004308195
   Coding: 418A0F030004140000110D000000000000087F075C
   Shop #: WSC 24000 576 14151
   VCID: 2B552BE18AA6501CA2-807E
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00063477
   Shop #: WSC 24000
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     170706 014  1201
   Coding: 00471077
   Shop #: WSC 24000
1 Fault Found:
00924 - Relay for Headlamp Cleaning System (J39)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 73
                    Mileage: 410142 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 11.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0MDV3W
   Coding: 0020788
   VCID: 3D7115B964D2CEAC0C-8068
   Subsystem 1 - Serial number: 6332MSME125C277EL
   Subsystem 2 - Serial number: 6342MSME125C225CD
1 Fault Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
            001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 035 0070
   Coding: 0000042
   VCID: 74E7F09D17184FE433-8020
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 912 D    HW: 1Z0 920 912 D
   Component: KOMBIINSTRUMENT VD1 1610
   Revision: V1610036    Serial number: SKZ7Z0F3727947
   Coding: 0007401
   VCID: 36630A9541E41DF4CD-8062
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Revision:   H52       Serial number: 310313F1000597
   Coding: 352303
   VCID: 74E7F09DD7184FE433-8020
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 410142 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:31:23
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1610
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         005 0944
   Coding: 0000758
   VCID: 387F04AD4BF0EB84DF-806C
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V3.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   Shop #: WSC 02069 000 90108
   VCID: 35610D995CE216ECC4-8060
Address 46: Central Conv.        Labels:. 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0202
   Revision: 00020000    Serial number: 00000000000000
   Coding: 19801A085283007F3F04850540085F96907CA0
   VCID: 0305A34142B6785C3A-8056
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Component:   Sounder No Answer
   Subsystem 7 - Component:       NGS n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 73
                    Mileage: 410142 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:32:43
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000758
   VCID: 397901A970FAF28C20-806C
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
   Component: BOLERO        009 0053
   Revision: 0A001001    Serial number: SKZ1Z3K8438595
   Coding: 0F0000000104
   VCID: 35610D999CE216ECC4-8060
2 Faults Found:
00856 - Radio Antenna
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 73
                    Mileage: 410142 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:31:40
01327 - Control Module for Parking Aid (J446)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 73
                    Mileage: 410142 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:31:30
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         005 0907
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 377D079146EEE4FCD6-8062
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000011
End-------------------------(Elapsed Time: 01:42)--------------------------
Did that previous autoscan help anyone? Or has it raised more questions than answers? Any help with this would be great, I need to get it sorted while I have the time. Cheers good folk!!
Edited by wig
I would probably have gone 0000132 as you have the MFSW. Not sure if you have maxidot as I'm not super familiar with pre-fl part numbers.
I'd also try using the measuring blocks to see if any position for the cruise control works.
