Fault codes Query
Hi all, 2005 Skoda Fabia, Mk1 1.4 100mpi. Keeps showing different fault codes. Sometimes the same, sometimes different. Only one or two faults show when the engine management light comes on. These, below are over two months. Would appreciate any suggestions. Thanks in advance.
Faults
17584 Oxygen Correction Behind Catalyst, B1 Limit Attained
17598 oxygen sensor.
17586 Linear 02 Sensor / Pump Current Open Circuit
17550 - Load Calculation Cross Check: Lower Limit Exceeded,
@manchesterman - Check the RossTech wiki.
  • Sponsor
Thoroughly check the brake servo vacuum hose for splits where the hard plastic pipe sections terminate.
