Skoda Fabia 2011 1.2 Radio Question
Afternoon all!
I am currently thinking about changing out the radio, i've seen how to remove it etc, but my question is this.
Instead of going out buying a kenwood or w/e, Can I upgrade it to a Skoda radio? Presently mine is a Swing but I need bluetooth (for music and phone calls) - I already know its a double din So please could someone recommend one that fits without getting adapters.
Else i'll probably look into converting double to single
Depending on the age of your car, have a look at the RCD330 (search 'Skoda RCD330' on fleabay). Fitted one to my wife's and it works very well indeed. If it's a facelift it will slot straight in without issue, if it's a pre-FL I believe you need a canbus adapter but don't quote me on that:
How can i tell you the age of my car? I know its a Skoda Fabia Hatchback 2011 HTP 1.2
The FL was released mid-2010, therefore your 2011 is the facelift and this would slot straight in.
Be sure to read the reviews as it does lack a few features such as full RDS AF (auto-frequency swapping as the signal weakens), but offers built-in Bluetooth, SD slot for audio (only MP3 format unfortunately) and Android Auto/Apple Carplay/Mirrorlink - just be sure to get the right version ("no-name" branded 6RD 035 187B model). The fleabay "Skoda RCD330" listings are the correct version from seller eodaworld.
Good Gravy! - Didn't expect them to be THAT expensive! Back to the drawing board and a Bluetooth adaptor me thinks
Do we know if there is any wiring diagrams for the original swing radio? I have an idea.........
What do you need to know ?
Wiring diagram may not help depending on what you want to do because of the internal curcuitry
I'm basically looking into replacing the head unit and making PiCar and I need to connect in an Amp so my speakers still work
Thats easy, buy the appropriate ISO connector for your vehicle, and there will always be a remote +12v to switch on an amplifier etc.
Whats a Picar ?
Whats a Picar ?
Raspberry Pi flashed and modded to suite a car stereo. Smart Radio
