312mm Brake line bolts.
Hello guys.
Recently bought Audi TT front callipers and carriers to fit on my fabia vrs but they came without bolts for the brake lines. Are the brake line bolts from the 288mm the same so i can reuse them? If not what size are the tt ones?
Yes, they should be identical.
Thank you!
When I make HEL lines for the 312mm set-ups I add about 15mm on them as the standard lines can be a little tight. All fitting and bolts are the same though :)
Thanks !
