abs and trac light on
Firstly, check the fuse strips on top of the battery. Look very carefully as they can develop very fine cracks.
Like this...
Edited by TMB
There are two other fuses for the ABS on the battery fuseholder, fuse 7, a blade fuse just to the right of those strip fuses under a cover, with a thinner red/green wire going to it,  and fuse 9 or 10 (depending on build date) with a red/white wire going to it. Have a look at those?
Recently my abs/asr lights were on permanently, lack of brakes, garage checked it out and the rear o/s abs sensor wasn't powering up. So new abs sensor and it's sorted. 2006 vrs, can you get it checked by vag.com or vcds.
