Cruise Control issue mk2 vrs
So i just had my squib changed, i sourced the part myself from ebay, i had it fit by a local mechanic who failed to change my stalks over, and just finished doing so.
Its the same part number as just came off it, but for some reason my CC doesn't work now - could it be the new squib? I'm kind of lost as to what to try here.
Any help would be appreciated!
You should have someone scan it using VCDS to check for fault codes and how it's coded.
Ideally you should have done this before having it replaced to verify the hardware, software and coding matches.
What is a squib?
If it is the main ECU then there is a coding for cruise control, I fitted a remapped one and had to recode it to get my cruise control back.
