mk1 vrs headlights wanted
as above . i'm looking for a set of headlights (as new )condition .mine have gone cloudy again and make the car look awful .also a bike carrier ,roof or boot mounted .
you can e-mail me at [email protected],,,cheers
Or, just simply use 'Tooth Paste' and plenty of polishing.
DB.
16 hours ago, Yaris said:
i'd rather clean up my genuine Skoda ones than fit cheap non genuine items.
This is what you need, and a drill. They'll come up like new https://www.ebay.co.uk/itm/AUTOGLYM-HEADLIGHT-RESTORATION-KIT-500ML/263257740804?hash=item3d4b625604:g:KAIAAOSw-0xYT97t
I've had a set of sub-£100 Depo ones off ebay on my car for a good while now and they are great. I previously restored my old lights using a 3M kit that worked great but they eventually started to fade again, even after regularly applying headlight protectant. I put Osram Night Breaker bulbs in the new lights and am more than happy with them.
I cleaned mine with 150 grit down to 2000 grit sandpaper till all the scratches were out then used two part clearcoat on them good as new and the two part clearcoat doesn't haze, it's expensive but worth it. You will have plenty clearcoat left so plan to do other touch ups on the car at the same time so that you don't waste it.
DB.
Got MOT Friday so hopefully Colgate will clear them up.
I’ve got a pair that I took off my Vrs if you’re interested buddy.
