engine fault
My coil light has popped on and engine management light are both on coil light flashing other on all the time. The car has know went into limp mode. Has anyone got any ideas. This came outa know where.
Best give a clue what the car and engine is.
& is it tuned, modified or something?
Is it the Yeti 2.0TDI you asked about remapping and did you have that done?
Edited by Skoffski
Skoda yeti 2.0L 4x4 elegance. glow plug coil goes on then goes to limp mode. engine light thin comes on. I turn the car off works for a bit then same.
No not yet as this has come about.
Thanks, but what year? And if in the EU, has it had "the fix"?
And it would also be helpful if you stated what your location was.
From past experience, we know that the coil light flashing can cover numerous "problems" so I suspect that the first thing you are to have to do is get the fault codes read.
