Ignition key won't turn
Hi, first time on this forum and your help would be great.
I have a problem with the ignition on my '56' Octavia, I can insert the key into the ignition but I am unable to turn the key, I also noticed that steering lock isn't on as I can freely turn the steering wheel without the key being in.
Any help would be greatly appreciate.
Try a squirt of liquid magic AKA WD-40
Is it an automatic? If so, the lever might not quite be in Park. The car then won't let you turn the key.
Happened to me once....:blush:
if the above advice fails sounds like the mechanism in the ignition barrel has failed and you will need a new one
