Superb MK3 Bi Xenon Lights
Hi,
Apologies if this has been covered on another post.. I notice that my dipped beams are a bit too.... Dipped in my Sportline. I picked the car up maybe 6 weeks ago. The high beams are amazing, light output and all is very good just the low beams are a bit too short. Has anyone raised the height of them? Or have any tips?
Yes. I raised mine with the manual adjusters on the headlight themselves. Vast improvement!
If they are "very dipped" there is an issue where they don't return to the correct position at the end of the dance when starting the car.  There is a fix from Skoda for it which appears to work.
There are other threads about it.
If they are just not quite as high as you would like them then think about the driver coming the other way having to look (almost) into them.
mine were very low to begin with, had to be enabled in the software.
Do your lights move when driving, you will be able to see them change beam "shape" when increasing speed not just turning
+1
U can easily adjust them manually, to make minor adjustments, up or down, left or right, assuming ur headlight isn't in failsafe mode, in which case they will point all the way downwards.
