Auto Lights Retrofit
Has anyone attempted to retrofit auto lights on the mk3. It’s the only feature I don’t have on mine that I really miss! Probably going to attempt at some point. Any info would be appreciated!
Cheers mate
I am in the process of trying to retrofit the just the auto lights. The part number I have is 6v0907451  the guide says connect pins 1 and 4 but I only have 2 and 3 on my sensor
uc?export=download&id=1O9V6JgZ4Djw503Ebr
pins 2 and 3 serve as a sensor for automatic air conditioning. 1 and 4 are for the light sensor
  • 6 months later...
Hi Have now got a new light sensor from the skoda dealer with pins 1 and 4.
And have setup the coding using the guide wirer.sk
But i have an error code in vcds
950280 - Light recognition sensor
          B13CA 29 [009] - Signal Implausible
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 200
                    Mileage: 85306 km
                    Date: 2020.12.11
                    Time: 20:30:21
sensor voltage is stable at 0.6v when plugged in and does not change when dark or in daylight.
Sensor voltage is 5v when unplugged.
Lights are always on in auto position
Has anyone got any ideas
On 05/04/2019 at 13:15, wirer said:
yes. "easy light", only light sensor - https://wirer.sk/easy_light/
but manual only in slovak lang. use translator
I went with the dashboard light sensor and followed wirer's manual. Happy to say it works brilliantly and I also get a auto light switch :)
Do you have vcds? Would you be able to check what your sensor voltage is when bright and dark. Its under central electrics advanced measured values. I wonder if my wiring has too high resistance.
Does anyone know how this sensor works. Is it a photosensitive resistor. And the bcm calculates voltage drop over the sensor. Or is it more complex.
No probs mate will check for you and get back.
  • 4 years later...
Where did you get it from
It is over 2 years since @singh946 signed in.
