Roomster starting problem
Hi daughter just got a 2008 1.4 TDI. This week twice wouldn't start, abs and handbrake light on and beeping.but then cleared and started. Now won't start at all. Any ideas so I can talk to dealer with some knowledge? thanks
A warm welcome to the Forum !  Perhaps post this in the relevant model section.
Hello Dpgn , welcome to briskoda , good to have you with us ,put the battery on charge , see if that will help you .
Battery has the charge indicator glowing green so don't think that's the problem. But thanks for the suggestion
Checked for fault codes none appeared, so appears to have been a faulty starter motor. Replaced seem all ok now.
Edited by Dpgn1960
Good to see you have it sorted . B)
Sadly today appears to have reoccurred. Does anyone know what the red box on top of the battery is, as don't know if this is a coincidence but hit it and sometimes it seems to clear the fault and starts.
