Superb 2017: Multiple error codes
A friend went to start their car yesterday at home and encountered multiple fault issues:
Auto Hold is Unavailable
Error:Brake is unavailable. Visit workshop
12V battery low. Charge by driving
Fault:automatic headlight control
Error: cornering light (afs)
Error: tyre pressure loss indicator
Front assist unavailable
Thoughts on any ideas most appreciated.
Ta
Wile
I'd start with the easy option - charge or change the battery. Never had an issue like this myself, but have read on here that a weak battery can kick up all sorts of problems. There are also threads on a bad batch of batteries on here.
The reason I say this is that the only other thread I remember about multiple faults was caused by rodents eating through wiring - not good.:sadsmile:
Cheers Jeff. I've suggested they disconnect the battery for a while then reconnect. If a dodgy battery then it should, in theory, re-appear. I didn't realise there had been a batch of dodgy batteries.
Wile
This thread mentions that there were some problems with Moli batteries. It also suggests getting Skoda Assist out (a good idea anyway) as if they confirm a duff battery then the dealer should replace it under warranty.
This is what you don't want it to be.
Thanks again Jeff. Will take a look under the bonnet and it's going into the dealer this week. Will post back.
Wile
I also own a 2017 Superb. Had the same error’s. Battery was replaced under warrenty.
