AUQ Engine upgrade help
Hi all,
I am looking at custom fitting a large turbo to my car and do all the necessary internal modifications required to accept it.
I will also be buying/getting made/making a manifold and exhaust system.
Ideally, what would people upgrade in the engine and what parts would you use?
I think:
New forged Pistons
New forged con rods
New big end bearings
new valve stem seals
new oil pump
new water pump
High HP capable timing belt kit
Thank you for the help
What power are you chasing?
You can quite happily make 300HP on stock rods. Maybe even 350 - its aggressive torque that kills these, as long as power is smooth, the stock rods are fine.
Realistically, they are the only major bit you'll need to change - they are very thing and snap with power.
Mainly this:
  • Big Turbo
  • Manifold
  • FMIC
  • S3/TT225 MAF Housing
  • Injectors (550c or so)
  • Turbo back exhaust (decat or sports cat)
  • High flow intake
  • Upgrade Rods (advisable over 300hp)
  • Highflow Fuel Pump (Depending on power)
  • Upgraded pistons (depending on power)
Edited by sakta
I am chasing 400+hp
I have a large blower already.  Mamba GTX2871R
the new exhaust manifold will be sorted soon.  e.g https://www.ebay.co.uk/itm/1-8t-Turbo-Manifold-Golf-4-Audi-A3-S3-8L-A4-A6-Tt-Polo-9n-Seat-Leon-Exhaust-T25/233183658004
Exhaust I will be sorting once all engine work completed.
I have new valve stem seals, Valves, bronze valve guides, oil pump and pick-up coming.
Looking at a new water pump and cambelt (any suggestions to hold the power)?
I have an oil cooler.
New radiator
I have a front mounted intercooler
I have an induction kit
Was looking at this:  https://www.ebay.co.uk/itm/MAF-Sensor-Flange-boss-80mm-TIP-Wideband-Vauxhall-Cupra-R-GTI-VW-1-8t/182485762653 but would you say not to and get a standard one from a different car?
I was looking at new rods, pistons and fuel system. I have some uprated injectors already that are: 850cc (4x used Siemens Dekka 850cc)
I was looking at this https://www.ebay.co.uk/itm/Uprated-High-Flow-Fuel-Rail-for-Golf-Gti-Audi-Seat-VAG-1-8T-20V-20VT-1997-2004/113082527548?hash=item1a543e6f3c:g:4UEAAOSwQYZWztA8&frcectupt=true or https://www.ebay.co.uk/itm/Aluminum-High-Flow-Injector-Fuel-Rail-kit-for-Audi-VW-1-8L-Turbo-20V-Purple/151913251975?epid=15008426030&hash=item235ebc4487:g:NLoAAOSwa81aRvNX
Whats thoughts on this, Also what fuel pump(s), fuel pipes (braided) and pressure regulator would you suggest?
What breather system/catch can would you suggest?
Edited by ColinD
formatting
