Secondary Coolant pump relay location
2011 Superb estate. 2.0 Tdi.
Had secondary water pump replaced, warning light still on.
Where is the relay for the secondary water pump located.
Have a fuse map but no relay map.
Skoda dealers will not give any info.
Surely this should be in the handbook ?
  • Sponsor
If you can tell me the engine code, I may be able to find it (later).
Edited by Wino
Engine number CFFB517286
  • Sponsor
Will have a look for you when I get home from work.
Edited by Wino
Thank you
  • Sponsor
No relay on the first circuit I've looked at.  12V feed from fuse 24, earth, and control signal from engine ECU pin 30.
