Octavia Brakes Question for the Techies
I have been toying with the idea of upgrading the rear brakes on the 4x4.
Now sitting in the garage is a virtually brand new set of callipers & discs that came off the front of the 4x4, would it be possible to fit or easily adapt these to go on the back ???? maybe use the callipers & diff discs.
I guess its a no no as Im sure I would have heard of this before if you could.
failint that I guess its a s/hand set of TT or S3 callipers etc
  • Administrators
Stuart,
When I spoke to Bill about his uprated fronts he was talking about too much rear brake and wishing to almost remove them, i.e. but a really cheap road pad on.
Now I know the ibiza is smaller and far lighter, thus the rear will lift more; causing overbraking lock to kick in...
What I'm getting to is; are you actually in need of more braking on the rear given your ap front setup is doing most of the donkey work now.
However I also share the mind set that iccle rear brakes look plain stupid so should be made up to size...you may want to consider a brake bias option...but that is getting way outside my sphere of knowledge.
Agreed they look silly, thats one reason but Ive also noticed after a good thrash the back brakes are working quite hard as theres a reosnable amount of pad dust & the discs are a tadge warm, whether its braking Im not sure, Im wondering if its the ESP stability thing working hard.
I just started thinking yesterday when I came across the box of nearly new brakes in the garage & thought, will these fit ? If yes its a cheap mod
Nope, unless you fit a seperate handbrake.
Ian can do you a set of rear APs, think they're from a TVR.
I drove an Escort Cosworth with decent brakes - I thought mine were good but this had 380mm fronts with water cooled AP 6 pots and 350mm rear 4 pots with titanium pistons - direct from a WRC one! Absolutely awesome!! :D
Nope' date=' unless you fit a seperate handbrake.
I drove an Escort Cosworth with decent brakes - I thought mine were good but this had 380mm fronts with water cooled AP 6 pots and 350mm rear 4 pots with titanium pistons - direct from a WRC one! Absolutely awesome!! :D[/quote']
trust you mean Ian (tavia4x4)
Re the cossie I guess that set up would cost as much as my car, nice experience driving it though
  • Administrators
Think he meant Godspeed...
Must admit my rears normally look dustier than fronts...
Yep, Godney not Cook :D
He was going to fit some 288mm or 312mm single pot ones on mine - he's done it before IIRC
Yep, with you
Yep, with you
Stuart, is Ian still doing the AP 4 pot kit for the Octavia, if so how much.
4 or 6 pots are still available, even behind std Octy RS wheels. You will need to contact Ian for prices, my 4 pots were
