1KZ & 1KU disks compatible?
Looking for some rear disks. The 1KU are considerably cheaper. What the difference?
1KZ are 310mm diameter and ventilated
1KU are 300mm diameter and solid
Bore Ø [mm]15,3
Brake Disc Thickness [mm]22
Brake Disc TypeVented
Centering Diameter [mm]65
Diameter [mm]310
Height [mm]48,5
Hole Arrangement / Number09/10
Inner Diameter [mm]169
Minimum Thickness [mm]20
No. of holes 29
Number of Holes5
Pitch Circle Ø [mm]112
Weight [kg]6,8
Fitting PositionRear
Fitted Quantity2
PR Number1KZ
Brake Disc TypeSolid
Diameter [mm]300
Height48.3mm
Hole Arrangement/Number5
Thickness12mm
Fitted Quantity2
PR Number1KU
