Tyre pressure help, please.
Hi,
Please help a hapless american understand tyre pressures over here. I'm us to Psi and am wondering how much tyre pressures increase in bar when tyres are warm? My front end was feeling a little "squidgy" today, and I've read on here that the Vrs is very sensitive to pressure changes. I'm on stock wheels and stock Turanzas.
I know I should just measure before driving and then after driving, but if you saw how dirty my wheels were, you'd understand my hesitance to touch them. (I'm giving her a good wash tomorrow, her first:thumbup: )
Cheers,
Will
Easiest way to convert is to remember that 1 bar =14.7 psi . To convert from psi to bar divide by 14.7
Once you've worked out the relevant figures stick a small note inside the filler cap to remind you! I've tried and tested. It works!
2.3 Bar = 34 psi (front).
2.2 Bar = 32 psi (rear).
And tyre pressures go up 1.6psi per 10 degrees C.
Chris
Thanks for the help, guys!
