Octavia radiator fan on from cold
Recommended Posts
Have a look at this - shows the location of the tempertaure sensor. They are really easy to replace, like bulb easy, and cost buttons to buy. You will loose some coolant in the process, so have a litre or two to top up once replaced. Best done on a cold engine to avoid scalding yourself.
Link to comment
Share on other sites
Cheers for that Westbury63 ....looks slightly different than what I remember when i took air box out to do the radiator sensor which should have been an easy job but Clip that held it in was metal and just fell apart when I tried to remove it and took a while to dig it out...lol
Atleast i roughly know where to look now so thanks for sending video clip
Link to comment
  • 10 months later...
On 02/06/2019 at 16:39, silverback1972 said:
I had the same symptom ( not saying it's the same fault) with my MK 2 Octavia. The fan would come on within 5 mins of starting  and revs would go up, fuel economy went South. It turned out to be a dodgy DPF sensor. Even though the DPF light didn't come on the car kept going into regen mode. Sensor changed and it fixed the issue.
Hi. Did this not show up as a fault code? As my fan comes on and the revs go up to around 1k after starting the car every morning, and the engine is a bit rough for a while. It seems to drive better later in the day, but it can do the same thing with the fan & revs.
Link to comment
26 minutes ago, silverback1972 said:
The engine management light came occasionally and that pointed to the sensor but the fault occured many times without the light coming on.
Ok, thanks for the reply I've had no lights come on
Link to comment
Do you have a DPF on your engine ?
If so, it sounds like the classic characteristics of the ECU trying to instigate a regen of the DPF.
If you've been doing lots of short journeys it probably hasn't been able to complete a regen.
Take the car on a longer run next time you use it ( probably 10 miles will be enough ).
If the fans are off when you get home the regen will have completed.
Link to comment
Hi. I do yes. I do regular long journeys. And short journeys. But this doesn't seem to improve the fault. This engine only has one main fan btw.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
