Replacement Stereo - 2015 roomster
HI,
1st post so please go easy!
I've just bought a 1.2 roomster 2015 plate.
want to replace the stereo with something androidy.  Any recommendations  - ideally would like something with rear camera, bluetooth, and ability to use google maps etc.   don't want to spend bucket loads, but want something thats reliable.  any recommendations or non recommendations would be most welcome.
cheers,
tom
Hi, the best person to talk to is, Rustynuts on this site.  Go to parts for sale he has things your looking for on there.
I spoke to him but he suggested that as I was probably looking for something non skoda best to ask on this forum.
Think I’m going to be going for one of these
Jvc
with regards to steering wheel controls and fascia and also rear cameras..  any recommendations?
That doesn't have Android Auto, just Android mirroring. ;)
Yeah having read alot about android auto.. Not too bothered tbh!
Okay, your loss I guess.
any recommendations for harness kits/fascia's?
guess any half decent reversing camera would do the trick?
so found the ATOTO A6 Pro VW edition.
Would this fit?
https://www.amazon.co.uk/ATOTO-Navigation-A6YVW721PRB-Entertainment-Multimedia/dp/B076GK5W87/ref=asc_df_B076GK5W87/?tag=googshopuk-21&linkCode=df0&hvadid=310873119586&hvpos=1o1&hvnetw=g&hvrand=4505260079137543924&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9044965&hvtargid=pla-573142326919&psc=1
Says that is directly compatible with:
  • A6YVW721PRB/A6YVW821P/A6YVW710PB fits most old Volkswagen models that have the similar dashboard radio opening (Applicable to Volkswagen models that OEM factory radios are of RCD 210/RCD 310/ RNS 310/ RNS 315/ RCD 510/ RNS 510. Factory OEM radio of RCD 550/RNS 810/RNS 850 is inapplicable). Specific VW plug-n-play harness connector is included;
  • If your car has original steering wheel audio control, A/C conditioner display, Parking sensor, they will be retained by VW CANBUS decoding box included in the package. Original reversing camera of certain VW models can also be retained as long as it put CVBS RCA signal out, or else you need extra video decode device (write to us for more information);
Is that compatible as a replacement for the Skoda Swing?  Am I right in thinking that the Swing is the same as the RCD310?
  There is no Steering wheel controls on my Roomster, and not  overly bothered if the sensors work through the headunit as plan to put in a rear camera.
Edited by thomasw88
In the end went for the ATOTO A6 Pro.   The VW version. Fits perfectly, and so far has been great!      You can tether your phone to it via bluetooth or wifi  hotspot  (more battery drain)  and in effect it works as a full android tablet in your car that way.
Is the 15 plate using the mk1 model, we just picked up a 14 plate and I am looking to replace the swing unit with something a bit better, Bluetooth and the like to keep SWMBO happy
I  think it was.
Anyway the atoto just fitted in nice and easy.   Could maybe be a little speedier in its actions ie finding routes on googlemaps isn't very quick and theres a bit of a lag between switching apps but apart from that its been great.
They do a newer none VW version which has more storage space and requires you to buy a connector/front fascia, but it looks a bit better spec and If I was buying now I would have got that one.
Edited by thomasw88
7 hours ago, thomasw88 said:
I  think it was.
Hi,
Atoto best on the market that I have found ...
The Atoto 10.1" Universal Pro 2U available on Amazon.de is really great.
https://www.amazon.de/ATOTO-A6Y2721PRB-Android-Navigation-Stereo/dp/B07BKT13NM?th=1
Fits with a standard VW dash mount adapter - £8 on theBay.
Atoto do the VW custom loom with a CANBus decoder for ~£27.
Need the VW FW available from Atoto.
Need to set Hidden Menu Item for SimpleSoft CANBus Decoder - Hit ModelNo. x4 Password 1617 - CANBus Menu ...
Aliexpress other seller CanBus decoder may work better ! ~£12.90
VW-RZ-08 Link - Cable wrong but decoder good.
https://www.aliexpress.com/item/32949408532.html
Edited by petrev
Let us know how it goes
Don't know who that was for ?
Anyway ...
Video of my unit
