My adopted sprint yellow VRS
12 minutes ago, KenONeill said:
What does that actually mean though? I had a Citroen BX 1.9XUD with the following running in instruction "do not exceed 4_000 (four thousand) RPM for the first 600 miles".
That engine had a governor that cut in at 4_600 RPM.
Donโ€™t blow the bl00dy door ms off, as one Michael Cain once said ๐Ÿ˜›ย
  • Replies 55
  • Views 9.6k
  • Moving things slightly forwards (hopefully)ย  now I have never attempted this type of work before but what the hell if I make a mess of it all is not lost as parts a still readily available. With
  • With the rear beam, it all depends how far you want to go. To make it truly mint you'll need to drop it off the car, in itself not a big job but you will need to remove the rear brake lines which coul
  • Just an update, I fitted the new discs and pads to the front due to the fact that both fronts had pads friction material that detached from their steel backing plates once I got them off the callipers
Iโ€™m laymanโ€™s terms โ€ฆ..no redlining it. But I didnโ€™t need to say that really, did I!ย
Quite the reverse; the line was "You're only supposed to blow the b100dy doors off!"
Ah bugger, wrong way round. Feel free to shoot me.ย
Hi kenOneil, funny you mention a Citroen Bx, my lade Dad had two new ones, first a burgundy red 1.9rd with the rocker switch for indicators and rolling drum speedo, then a greyย  1.9 rd with normal switch gear, lovely cars.
On 10/05/2022 at 19:54, Titanium_Man said:
Yeah, Iโ€™m getting there thanks. One more hurdle to overcome then the rest is down to me :)ย
ย
No need to change the rockers if theyโ€™re not damaged, but will definitely need to lap in whichever valves you want to put in the new head, and I would 100% use engine assembly lube as new parts are going in.ย
ย
If money is no object, why not replace it all, including all the various bolts, gaskets, nuts etc.ย
ย
I would run the Engine for a week then change the oil, making sure itโ€™s given a few heat cycles and not extract the urine with revs during the first few days.ย
ย
Not an overly difficult job if you have the tools for removing the valves etc, but good luckย ๐Ÿ‘
Spent enough on the new head allready!
  2. Tap Permissions โ†’ Notifications.
