My adopted sprint yellow VRS
12 minutes ago, KenONeill said:
What does that actually mean though? I had a Citroen BX 1.9XUD with the following running in instruction "do not exceed 4_000 (four thousand) RPM for the first 600 miles".
That engine had a governor that cut in at 4_600 RPM.
Don’t blow the bl00dy door ms off, as one Michael Cain once said 😛
  • Replies 55
  • Views 10.7k
  • Moving things slightly forwards (hopefully)  now I have never attempted this type of work before but what the hell if I make a mess of it all is not lost as parts a still readily available. With
  • With the rear beam, it all depends how far you want to go. To make it truly mint you'll need to drop it off the car, in itself not a big job but you will need to remove the rear brake lines which coul
  • Just an update, I fitted the new discs and pads to the front due to the fact that both fronts had pads friction material that detached from their steel backing plates once I got them off the callipers
I’m layman’s terms …..no redlining it. But I didn’t need to say that really, did I!
Quite the reverse; the line was "You're only supposed to blow the b100dy doors off!"
Ah bugger, wrong way round. Feel free to shoot me.
Hi kenOneil, funny you mention a Citroen Bx, my lade Dad had two new ones, first a burgundy red 1.9rd with the rocker switch for indicators and rolling drum speedo, then a grey  1.9 rd with normal switch gear, lovely cars.
On 10/05/2022 at 19:54, Titanium_Man said:
Yeah, I’m getting there thanks. One more hurdle to overcome then the rest is down to me :)
No need to change the rockers if they’re not damaged, but will definitely need to lap in whichever valves you want to put in the new head, and I would 100% use engine assembly lube as new parts are going in.
If money is no object, why not replace it all, including all the various bolts, gaskets, nuts etc.
I would run the Engine for a week then change the oil, making sure it’s given a few heat cycles and not extract the urine with revs during the first few days.
Not an overly difficult job if you have the tools for removing the valves etc, but good luck 👍
Spent enough on the new head allready!
