I made a VCDS scan now i would like some help
Iam atacching the file could not paste it here so it looks normal.Please help me to understand the fault codes please.
5 Faults Found:
23595 - Active Radiator Shutter 1 P05A3 00 [032] - Implausible Signal Intermittent - Not Confirmed - Tested Since Memory Clear
17158 - Databus U1123 00 [032] - Received Error Message Intermittent - Not Confirmed - Tested Since Memory Clear
21606 - Implausible Data Received from Body Control Module (Central Electric) U0422 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear
21605 - Sensor for Ambient Air Temperature (G17) P0070 00 [032] - Malfunction Intermittent - Not Confirmed - Tested Since Memory Clear
7150 - Implausible Data Received from Steering Angle Sensor Module (G85) U0428 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb Part No SW: 5E0 920 871 D HW: 5E0 920 871 D Component: KOMBI 333 2210 Coding: 07A40A102990000801086A00000000 Shop #: WSC 73430 031 00000 ASAM Dataset: EV_DashBoardVDDMQBAB 008031 ROD: EV_DashBoardVDDMQBAB_008_VW37.rod VCID: 295E26E6486262099E-807C 1
Fault Found: 1048578 - No Basic Setting B2010 00 [009] - - Confirmed - Tested Since Memory Clear
Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 227 Mileage: 159013 km Date: 2019.06.12 Time: 14:43:19
1 Fault Found: 65639 - Motor for Window Regulator B1487 29 [008] - Signal Implausible Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 1 Mileage: 117098 km Date: 2017.11.24 Time: 18:41:08
there are more in the pdf plese help me to understand them.
auto-gabi.pdf
i turned off the start stop by editing voltage to 13.6 but it still works , it was 7.6 originaly.
i cant find the error codes meaning :S
You've got to whack it higher than that to get it to reliability stay off. I read a post yesterday which recommended 18v.
It wont do any damage to the car right?
No, it serves no other function than as a threshold for operating the start stop.
  • 5 weeks later...
With the voltage cracked up the self scan wont work in the car colombus menu.
It will prompt you to start the engine with a running engine.
you need seatbelts on , start stop on, doors closed, engine running.
With voltage set higher Than 7.6V the car recognizes the engine is not running.
Watch out guys.
