Best oil to use in my new vRS?
Out of the following from the sticky here on these fine forums, what is the most recommended oil to use with a new vRS?
BP Special Visco V 5W-40 (fully synthetic)
Castrol GTD 505 01 5W-40
DEA Ultec Diesel SAE 5W-40
Delphi Prestige Diesel Plus 5W-40 (synthetic-based)
Esso 505 01 5W-40
Fuchs Titan Supersyn SL PD SAE 5W-40 (fully synthetic)
Granville Topaz Diesel 5W-40 (semi-synthetic)
Madit 505 01
Migrol Special S-Plus
Millers XFE-PD SAE 5W-40 (semi-synthetic)
Motul 6100 5W-40
OMV syn com diesel
Q8 Formula Excel 5w40 (fully synthetic)
Shell Helix Diesel Plus VA 5W-40 (semi-synthetic)
VAG-branded 505 01 505 00 High Lubricity Engine Oil 5W-40 - G 052 167 A2
- (Part No: ZGB 115 QLB 00 462 - RRP
Ok, so i guess literally all of the above?!
Check Out 'amsoil' Based In Hounslow/twickenham (and Have Plenty Of Websites -american Co.). This Is Probably The Best Synthetic Oil Available And Their Oil Filters Remove Particles Half The Size Of Standard Filters So Engine Wear Is Drastically Reduced. They Are Actually Prepared To Make Specific Claims As To Potential Mpg Gains That Other Manufacturers Such As Mobil 1 Are Not Prepared Tom Make.
I'll Be Running My Next Vrs With Their Oil And Filters!
All of the listed oils meet the spec required - so yeah pretty much :)
I just use the standard VAG stuff as it all does the same job ;)
