Superb options you can enable with vcds?
  • Administrators
Hi, I'm spec hopping on used models :D
Given a car already made, has the camera through the option of Light Assist with high beam control.
Can the option of Lane Change & blind spot assist be enabled afterwords?
And on the above combo vice versa ;)
And can Travel assist with traffic sign also be coded?
/cc @Gizmo thoughts?
Edited by ColinD
There are two camera options:
- The lowline can only do high beam assist
- The highline can do lane assist, traffic sign assist, smart/dynamic light assist and high beam assist
Generally speaking, if the camera is attached to the screen looking through a trapezoid/triangular cutout, it'll probably be the highline. If it's built in to the rear view mirror mount, it'll be a lowline. Couple of images can be found in this thread: https://www.briskoda.net/forums/topic/437223-lane-assist-with-full-led-afs/?do=findComment&comment=4919152
From your description, it sounds like the lowline camera so it won't support the extra functions.
As for blind spot assist, that requires two additional radar units under the rear bumper and LED's in the wing mirrors. It's very unlikely the hardware will be present and not activated.
  • Administrators
Super thank you. I've been looking for the triangle cut and I'd missed the low/high specificity till now.
