00470 error
Hello, everyone!
I tested my SO2 FL a few moments ago and I found an error I don't know how to fix.
I must tell you I activated the whipe function of the instrument cluster and before it no such error had appeared.
I took a picture of the log and post it here.
Anyone?
I found something about the radio and some function of it which, when active, may generate this error. I need some more looking into it.
No battery drain in my case.
Still hoping someone fixes this error in the past and won't mind sharing the solution.
Thank you!
It's probably a bad wire or connection.
CAN bus uses a twisted pair of wires, both are used to send the same information but use opposite signals. That error suggests the comfort CAN bus has a fault on one of the two wires so is only using one wire to communicate.
Given its intermittent, I'd clear it and see if it comes back.
If it does come back, post a full autoscan rather than just a picture 🙂
My car's comfort bus has been in single wire since before I bought the car four years ago. So far it has not caused any problem.
Unless it becomes a nuisance I will ignore it. Probably caused by a poor connection in a connector behind the dashboard.
2 hours ago, deejaystar said:
I will delete the error and see what happens.
When I delete the error it soon comes back, but ignore it. its not critical.
I wouldn't like that. I like the log to be clear.
So, like I wrote above, I found something about a stereo function which if active, generates, or may generate such an error. Anything about this?
I found this: "As an update to others who may have this problem: It was the wiring harness in the door. Specifically, inside the accordion boot between the A pillar and the door the wiring had been cut. We had a problem with this harness before and the VW dealer supposedly had replaced it. Turns out he had only "repaired" it, splicing a butt connector in inside the boot. Yes, seriously. Anyway, I did a better repair and now it appears to be entering sleep mode and the code has disappeared" source.
I wonder if it is possible for a 2012 car. But I am going to check it out. It is easy enough.
One more thing: a month ago, I replaced the left front door switch, but I checked the car for errors, and found none related to it, after completing the replacement. Weird. I am also thinking about that TPI function (or something similar).
So, I deleted the error, drove about 40 kilometers, no error whatsoever. I don't like this abracadrabra error situation.
I also saved a log. If anyone wants to see it, I will upload it.
This is the actual log with the error which appeared again:
Wednesday,31,July,2019,09:48:23:00008
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 19.6.0.5
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: TMBCA21Z9C2168036   License Plate:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 77
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (BSE)       Labels: 06A-906-033-BGU.lbl
   Part No SW: 06A 906 033 NT    HW: 06A 906 033 MP
   Component:  BSE S71 1.6 2V     8459
   Revision: --H01---    Serial number:
   Coding: 0044071
   Shop #: WSC 73430 790 00083
   VCID: 7EF348F829F77DBFE4-802A
No fault code found.
Readiness: 0000 1000
Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
   Component: MK70 M MASR         0106
   Revision: 00H35001
   Coding: 0017665
   VCID: 7BF541EC3AE56897C3-802E
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 3T0 907 044 BK    HW: 3T0 907 044 BK
   Component: Climatronic   H18 0506
   Revision: 00001007
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 7CF742F0F7EB6FAFCA-8028
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 R    HW: 1K0 937 087 R
   Component: BCM PQ35  H+  110 0651
   Revision: 00110 AC
   Coding: 40000AB8A805089040100080150085E4430000AE520089605C8440000040
   Shop #: WSC 17874 002 1048576
   VCID: 408FF600D383CB4FD6-8014
   Subsystem 1 - Part No: 1Z1 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 11031  26  0601
   Coding: 00D7B7
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q2 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2VPLUT
   Coding: 0020786
   VCID: 3D718FF46471A6A7BD-8068
   Subsystem 1 - Serial number: 6332MSME6B2411286
   Subsystem 2 - Serial number: 6342MSME6B2411467
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 1K5 953 521 AE    HW: 5K0 953 569
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20120316801196
   Coding: 4080040000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 70EF66C0ABA31BCF66-8024
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 803 Q    HW: 1Z0 920 803 Q
   Component: KOMBI         H06 0608
   Serial number: 00000000000000
   Coding: 110A00
   Shop #: WSC 73430 031 00083
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
   VCID: 428BFC08D58FD95FC0-8016
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 060312F6001603
   Coding: 351302
   VCID: 3A7B84E8B55F919F98-806E
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 54
                    Mileage: 139841 km
                    Time Indication: 0
                    Date: 2019.14.23
                    Time: 02:30:13
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H06 0608
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB74A88D7FE11F28-803E
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2119
   Coding: 0000116
   VCID: 489FEE203BB3F30F1E-801C
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 67     3305
   Revision: 00H22000
   VCID: 377D9DDC464D8CF767-8062
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000116
   VCID: 479DED1C36ADFC7717-8012
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3T0 035 156 B    HW: 3T0 035 156 B
   Component: BOLERO        007 0053
   Revision: 0A001001    Serial number: SKZ1Z3I9881101
   Coding: 050004000000
   Shop #: WSC 33361 790 00999
   VCID: 2D51BFB4741136270D-8078
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 G    HW: 7P6 035 730 G
   Component: TELEFON       H09 2730
   Revision: 1B001001    Serial number: 00007660706285
   Coding: 0100000000010110
   Shop #: WSC 43117 134 05925
   ASAM Dataset: EV_UHVNA A01015
   ROD: UHVNA.rod
   VCID: 366390D8894775FF7C-8062
End-------------------------(Elapsed Time: 02:05)--------------------------
Any idea will be highly appreciated.
Thank you!
Edited by deejaystar
  • 8 months later...
