Right side doesn't work
Hello
Recently I got  a problem with the right side on a skoda superb 2
When I try to lock the door on the right side it doesn't work , I can't close the windows and I can't use the electric mirror.
on the care screen is show that the door is open, when I close them I still got that message, and I can't lock them.
basically I can't use the electric right side on the car...
Can I get any help?
More than likely broken wires in the door harness between body and door
Very common problem
Search on this forum there is loads of info😎
Edited by DEL80Y
More info
The problem is at both right side door, the wire from one door can affect both of them?
Yes  my rear drivers door was not working and stripped all the door down to find out the rear door controller unit gets power supply from front door and had three broken wires in front loom boot between A pillar and door.
The master control module for all the doors is in the driver's door.
