I need Bolero Update :-)
Paweł, can I please get an update :)
119067025_1223715867992985_8191566765300482199_n.thumb.jpg.76048e214617ffb2cae9f310c183b9d8.jpg
  • Replies 1.2k
  • Views 217k
  • My friends used to say: Point 1 - Pawel is always right Point 2 - if Pawel is not right then check point 1
  • All check your PMs
  • Sent via PM.   Guys you need to tag me if you want a link as I don;t have time to follow forum on regular basis... I drop me a PM.
Hi Pawel, is there any update available for this?
Thanks!
Hi.An update for my Bolero,please?!?Thanks in advance
@pab567 My dads radio has stopped picking up DAB radio for some reason. The option has just disappeared from the menu screen...
I'm wondering if a firmware update would fix this?
It's a Skoda Octavia Scout it's a 2015 model. The system settings on the the radio say:
Device Number: 5E0035020D
Hardware: 443
Software: 0370
Can this be updated at all? And is there anything odd about this hardware/software version on this model car at all? I find it odd that the radio has worked since 2015 and now is picking up zero DAB?
I'd greatly appreciate your help! Thanks. Paul.
Can this version be upgraded?
Thanks.
All check your PMs.
Keep in mind that SW upgrade does not bring any new features neither it enables existing but locked features (e.g. SmartLink).
@pab567 Hi!
Do you have an Update for my colombus? If there is an option to make it show Hebrew letters instead weird squares in my Superb 2017.
I had Octavia 2018 with the flat touchscreen and it shows Hebrew letters very well.
Thanks~
This is not Columbus, this is Bolero. I will PM link. As far as I remember Hebrew is available since MY18 which runs on SW 04xx (e.g. 0478). But updating from yours to 0478 requires unit to be open and soldered :(
If i long press on Car button it opens an hidden menu with android and tv etc.
MENU, not CAR
1 minute ago, pab567 said:
MENU, not CAR
Yes, is that means my bolero is soldered?
I don't think so, why do you think it is?
Going to jump on the update train, any updates out for this @pab567?
https://cdn.discordapp.com/attachments/405463223589142532/764953795762585680/20201011_214820.jpg
Link sent via PM
Hello,
Does someone have the latest software version for Bolero ?
5Q00035840B
Hardware:H30
Software:0363
@pab567
Hello,
Could I please get an update for my Bolero?
5Q00035840B
Hardware:H30
Software:0359
Thank you very much.
Check your PMs
Merci !
Hello,
can my model be updated?
And since mirrorlink is no longer possible for new users, is it possible to switch to smart link ?
Hello,
Please find attached a picture of my bolero system. Skoda Octavia III 5e 2016. Is it possible to update to the latest version? Thanks
@pab567 hi! is there an update available for my 2018 fabia se please. thank you!
Hi is there a software update for my Kodiaq ?
does it have to be updated from SD or can the files be on a USB ?
Thanks in advance
Adam
@Elona to have SmartLink you need to exchange the unit and have it reworked, pls contact me on PM if you are interested
@kris_s unfortunately I don;t have any SW for your unit
All other pls check your PMs
any update for this baby?
