I need Bolero Update :-)
Check your PM but I really doubt it helps :(
  • Replies 1.2k
  • Views 239.6k
  • My friends used to say: Point 1 - Pawel is always right Point 2 - if Pawel is not right then check point 1
  • All check your PMs
  • Sent via PM.   Guys you need to tag me if you want a link as I don;t have time to follow forum on regular basis... I drop me a PM.
Thank You - I'll give it a try and then i suppose I may have to look at replacing the whole system at some point.
Any updates available for Yeti?
Hello, @pab567
i assume nothings available for below?
Device: 5Q0035840A
Hardware: H25
Software: 0245
Media Codec:
2101.0.0.10
No updates for Yeti - there are units with newer software but nobody has this software available as update.
@mantask check your PM
On 04/02/2021 at 14:55, Gaveeno said:
Another S/W request
@pab567 I see that you are the man to ask!
I too am looking for any possible updates - especially since the touchscreen has started having phantom touches in cold weather!
It's the mirrorlink only 2015 version - Boooooooo.
Thanks in advance for any help you can give.
Gavin
My 2017 does this sometimes! So dont worry too much
Thanks, after reading through here it seems to be an issue loads of people are having!
It hasn't happened since I applied that update, but I'm not holding my breath!
Otherwise the car is excellent and I'm very happy with it.
Hello, @pab567
Another SW update request
Device P/N      5Q0035842A
Hardware        H24
Software         0241
Media Codec.   2101.0.0.8
Cheers
Simon
Check your PM
HI
I am interested in updating my Bolero.
I bought an used Skoda Fabia. Me was told that SmarLink+ is integrated but i only tells me Smarlink starts an thats ist. I hope an update will fix this.
Device Number 5Q0035819C
Hardware H41
Software 0468
Media Codec: 4101.0.0.0
Would be glad if u can help.
Btw - nice forum
Hi There @pab567!!
Another one here owning a 2017 Fabia MK3 with radio Bolero and mirrorlink on it, with the following version:
Hardware: H30
Software: 0361
Media Codec:
3141.0.0.1
I´ve never updated it since I bought the car ( I tried several times Skoda´s update portal, but it always said that no updates were avalaible for mi VIN number)
So I´ve got 2 questions....
Is there any update for my unit? (I guess yes there is since while going through the whole post I´ve seen people with Hardware H30 and higher Software values
In case there is, What is the use of the Skoda´s update portal? (Since it says no updates are available...)
Well... and my last question is (yes.. I lied a bit when I said it was just 2 questions, sorry!!) Are there any improvements with the newer software versions? (more stability, functions?)
Many thanks for your time and have a great day!
4 minutes ago, d_olalla said:
Hi There @pab567!!
Hardware: H30
Software: 0361
Media Codec:
3141.0.0.1
I did not mention the device part number (don´t know if it is relevant), which is  5Q0035840B.
Thanks again!!
11 hours ago, tlpb2 said:
HI
Hardware H41
Software 0468
Btw - nice forum
Unfortunately it will not - your unit does NOT support SmartLink, although this is included in the menu items. None SW update will have it sorted. The only solution is to replace unit mounted behind glove box - if you are interested pls contact me on PM.
@d_olalla detailed list of changes (so called change log) is not available, no new features, just bugfixes - check your PM.
Understood!
Many thanks for your time and support!
is there any update for my car? I have problem with android auto.
Check your PM
Hi is there a update for my car please.
Having issues with crackling via CarPlay and hoping an update might help! 5D50AA7F-8E03-4880-965A-3C6A7D48E1E4.thumb.jpeg.1fc65d057e5bfcb3857e4fd55527adc7.jpeg
7 hours ago, Oasismad said:
Αντιμετωπίζοντας προβλήματα με το τρίξιμο μέσω του CarPlay και ελπίζοντας ότι μια ενημέρωση θα βοηθήσει 5D50AA7F-8E03-4880-965A-3C6A7D48E1E4.thumb.jpeg.1fc65d057e5bfcb3857e4fd55527adc7.jpeg
 Please can you provide the latest software update available for Skoda Karoq  my device?  Part no. is 5Q0035840C, Hardware is H41 and the current software version is 0468. Many thanks.
10 hours ago, KARSO said:
 Μπορείτε να παρέχετε την πιο πρόσφατη διαθέσιμη ενημέρωση λογισμικού για το Skoda Karoq τη συσκευή μου; Μέρος αρ. είναι 5Q0035840C, το υλικό είναι H41 και η τρέχουσα έκδοση λογισμικού είναι 0468. Ευχαριστώ πολύ.
Hello, what is bolero update? Is it official update?
Device: 565035840
Hardware: H41
Software: 0478
thank in advance ^_^
Hi @ pab567!!
Please send me an update file for Bolero.
Thank you very much !
Hi @ pab567!!
Kérjük, küldjön nekem egy frissítő fájlt a Bolero-hoz.
Nagyon szépen köszönjük !
Device part number 5E0035819A
Hardware 040
Software 0421
Media codec N/A
