I need Bolero Update :-)
59 minutes ago, Golanl1978 said:
On 10/08/2019 at 22:49, pab567 said:
@HingAmHang tell me model number and SW version of your unit, you can find it in menu
@pab567 Hello man.. I was wondering if you could some how help me with some issue..
I would appreciate any help!
I have recently bought the new Skoda octavia (4th gen 2021)
recently, while driving I suddenly get push update notifications.
I pressed on “UPDATE” and got a screen with two options USB1, USB2.
Can I update the infotainment system firmware using this interface?
Is there any way I can download the firmware file to a USB drive and flash the firmware without taking my car to service?
Note that my VIN number shows there are no updates (Maps) for my vehicle while applying it on the Skoda update portal.
Bolero infotainment,
10 inch screen,
Octavia “Style” model,
VIN# TMBAR7NX3MY125820
and I live in Israel, if that is of any help.
Thanks in advance,
Golan.
  • Replies 1.2k
  • Views 239.7k
  • My friends used to say: Point 1 - Pawel is always right Point 2 - if Pawel is not right then check point 1
  • All check your PMs
  • Sent via PM.   Guys you need to tag me if you want a link as I don;t have time to follow forum on regular basis... I drop me a PM.
On 07/05/2021 at 17:39, pfluap said:
Thanks very much! Much appreciated. I don't know what ODIS or VCP are (apart from having a quick Google just now) - what's my best course of action? Do I need to buy a gadget to plug into my OBD port and some other software? Cheers.
I recommend to find in your area someone who has ODIS or VCP (Vag Can Pro). You can also visit your local Skoda delaer and ask to programm your unit using ODIS.
@Golanl1978 I beleive the process should be explained in your car user manual. If you don;t find it then rather check with your local Skoda dealer as I am not into MIB3 infotainment systems at all.
Thank man!
Hi,
I'm new to the forum and have just got a 2017 Kodiaq.  Are you able to tell me if there are any updates for my system?
Thanks in advance
Hi @pab567
i'm new to the forum and have got a Octavia 2017.
Are you able to tell me if there are updates for my system?
Thanks from Slovenia :)
Check your PMs
2 minutes ago, pab567 said:
Check your PMs
Awesome thanks man.
Safe enough to update? I assume it's much the same as a maps update?
Any patchy notes for each version online anywhere?
I have Skoda Rapid 2016. When I use CarPlay I can see album covertart when playing Spotify/Tidal. When playing via Bluetooth I see Bluetooth icon instead.
Can I fix this with firmware update or do I need new hardware?
Hi @pab567
Are you able to tell me if is there an update for my bolero? Could I  use smart link in it?
thank you in advance
Yes, you can use SmartLink if it is activated (if not you must have it activated). For SW update link check your PM.
Dear Pab567, greetings from Colombia,
Thank you for your help, you are very kind. I hope the update does not cause issues in my infortainment because I am in Colombia.
I will update my bolero today! :thumbup:
Regarding  SmartLink activation, a code is requested when I try to use. I asked the dealer by the code bur they say it is not installed in my car. It is necessary to install a aditional module in order to have smart link o it could be activated with software,
Thank you very much again,
Best Regards
Hi @pab567
I have updated my radio Bolero!
thank you very much.. Now, I have a new software firmware:
Hardware H30
Software 0367   (Before 0353)
Codec Media:  3141.0.0.2  (Before 3101.0.0.9)
And how you said, smart link was no activated.
You are very Kind!
@pab567, is there any update for me? Yesterday the screen froze (the buttons were still active, but no change on the screen) and this morning my car battery was exhausted, I guess because of this screen froze. Thanks in advance!
Disconnect your car battery for 5 Min. It supposed to work and get to the normal state
Bull****, no additional module is required, just the activation.
Unfortunately you already have the latest software.
Hi @pab567
I have:
Partno: 5Q0035874A
Hardware: H24
Software: 0253
Is there anything higher for me
best
Nope :(
1 minute ago, pab567 said:
Nope :(
cheers
Hi @pab567,
I have a Fabia with partno 5Q0035840B, hardware H30, software 0353
and a Kodiaq with partno 5Q0035864C, hardware H41, software 0471.
Do you happen to have any updates for these? :-)
BR
PM
hello. I am new here and I am wondering if there is any upgrade for my radio. Thanks in advance
5 hours ago, Edin said:
hello. I'm new here. I have a radio with factory software. I'm wondering if there is any upgrade for my radio with newer software by installing smartlink. Thanks in advance
@pab567
Hi Pawel...   Just wondering if you have an update for the following Bolero in a 2018 Kodiaq?  We're struggling to get our Android 10 phones to connect via smartlink so we can use satnav from the phones so wondering if an update will help.
Thanks in advance.
Edit: the lack of connection to our phone actually looks like it might be because they are both Android Go based phones and apparently android auto isn't compatible with Go...   Doh!   A software update might still be useful though...
Edited by skomaz
All check your PMs
