Part worn replacement on a haldex car?
  • Administrators
Hi all,
What do you reckon for for this scenario:
Front damaged tyre, needs replacement.
Other tyre on front axle is 5.6mm, rears are 6.2mm.
New tyre on 8mm of tread or two new tyres and pocket one as a spare?
2mm or 3/32" could be a fair bit of different rotation, not got the maths on me to figure out exactly what it is.
I know if it was a bigger difference it's a shockingly easy choice, two new tyres and rotate.
So early hadlex, this is a '19 car, early ones though didn't like differences and I know systems like torsen didn't like differences between axles. But a new modern haldex, is 2mm tread differnce a worry?
Edited by ColinD
No worry at all.
The concern about different tyre sizes comes from all wheel driver/ 4x4 vehicles without a centre differential. Differing speeds front to rear causes 'wind up'.
The front and rear are decoupled most of the time and the ESP/ABS system software has to cope with such differences.
  • Administrators
:) I thought that might be the case but... :D If it was a 25k question on who wants to be a millionaire, I may of gone for it ;)
Edited by ColinD
The Haldex Gen 1 which was a mainly hydraulic pump had massive issues with different tyre size on the same axle and even across the car. The new ones are eletcronic and are fine.
  • Administrators
Super thank you. the newest is on the NSF, as that's the one that for me at least historically has worn the most and takes the most knocks.
