How to wire additional wires from fusebox to central console radio so they are quiet?
I already pulled four cables from the drivers side fuse box to the central console radio.
1 Rear Camera video cable, 1 rear camera video converter power cable and 2 CAN Bus twisted wires for the high beam assist.
Only the can bus twisted wires are twisted and covered with cloth tape.
I sometimes hear a ticking sound, one of the wires is knocking against the plastic of the car. The plastic beneath the steering wheel.
(Having a quiet car has disadvantages)
How should I wire the additional wires so they are quiet?
Edited by mbgar
I put an RVC in and taped the new cable loom to the back of the bulk head and the stuck them to the brackets / frame I could see.
whats an RVC?
Could you post a picture of your setup, please? :)
Rear View Camera.
Sorry I took lots of pictures when I put it in, but not under and behind the dash.
I use the factory flocked tape so the pvc doesn’t squeak or rattle on the plastic. In the tailgate or pillar trims, I wrap the loom in thin foam rolled into a tube.
