Do Superbs have heated seats?
And you have heated and ventilated seats. I have only heated.
  • Replies 59
  • Views 10.7k
  • Might be specification dependant and or year dependant.   my L &K has heated front and rear seats (well, heated and cooled front to be more exact).   but then again the L &
  • Hi, my SE-L has them, separate buttons near the aircon controls.
  • if it has heated seats fitted, you'll see this button, right next to the temperature value.....   and it looks like this on the infotainment, when u press the button....
18 minutes ago, Stonekeeper said:
@JR RS Yours appears to be a different infotainment unit than the one enquired about
It's the same MIB2.5 9.2" Columbus Unit, just dressed up in a different surround - Superb vs Kodiaq.
The Climatronic will b the same too, just different trim surround again.
50 minutes ago, JR RS said:
I have MIB2.5 High and heated/ventilated leather seats on my Superb, and when I press the Seats button on the Climatronic panel, I get the popup on the Infotainment screen to adjust the heating/ventilation levels.
Pic below is after I pressed both driver and passenger seat buttons.
Can You show me/us how the seat look like from the inside, meaning with the door open, front 3/4? Are they power seats too for regulations?
Edited by Benja77
What numer climatronic you have and what version software ?
What year od your car?
These r my seats - leather seats, powered, heated, ventilated.
My 08 Air Conditioning module is:-
Software number: 3V0907044DT
Software version: 4101
Hardware number: 3V0907044DT
Hardware version: H34
My car is MY17.
Edited by JR RS
Your 08 Air is very very new if your car i MY17, you replace it ?
Edited by pepeEL
My car is MY17.
Tell me also.... when example you play radio and when click on button heated seat what show your infortaiment ?
Next when play radio and change temp or swing to fron or on window what show your infortaiment ? Show menu clima ?
I haven't replaced or updated the Climatronic on mine - it came like that from factory.
Doesn't matter wat screen it's in, if I press the seat button, a small pop-up will show, not the full Climatronic menu.
I can then adjust it on screen or continue to adjust via that small pop-up.
MIB2.5 Home screen....
Android Auto screen.....
no, nothing shows up or changes on the infotainment screen.
I think about change my 565907044BG to 3V0907044CS but i dont know if i can and if it will be work ?
Mine is the same as @JR RS on facelift with MIB3 and Columbus. Overlay comes up in the bottom corner when you press the seat button at which point you can jump to whichever setting you like (hot/cold/1/2/3/off). It’s an overlay so the screen behind stays on what it was.
But when change airflow direction also show something popup ?
Why r u so hung up on something showing up when u change the temp or airflow?
Only ask to know how it works
e.g. 5NA907044AJ
Sad mine only does the airflow
You have Touch unit
So, I looked through some backups of my server. All vehicles that had the pop-up had a ECU with a software version 2002.
Edited by Cairus
I now have confirmation. mib2 Amundsen, SW 0480 with SW1804 climate control doesn't work. I flashed the climate control, and the display was immediately in the mib.
What’s the steps for that
Are you serious about the question?
Hi again. I buy for test newer unit climate 565907044DL. It is newer than my 565907044BG and has new software.
My old 565907044BG has SW 2002
New 565907044DL has SW 2801
but after connect also no show popup from geat seats.
I think that this option is to setup in adaptation or coding... because new SW with new unit climate no resolved problem.
Edited by pepeEL
I have Seat Coding on Skoda mib and it works
Wich mib?
