Hi all, I'm in need of a picture or info on the fabia mk2 1.6tdi maf sensor pinout, can't find a data sheet anywhere, my connector has been swapped I think it's wrong. Any help would be great. Cheers
What year and engine code ?
2011 105 not sure of engine code but it just a vw ag 03l 906 461 senor that need the pinout for. Cheers
OK so from Elsawin that would make it a CAYA , CAYB or CAYC but the connections to the MAF are the same, Pin 2 (Black/Yellow wire) is the 12v supply, Pin 1 (Grey/White wire) goes to pin 39 of ECU & Pin 3 (Grey/Red wire) goes to pin 18 of the ECU (both in the 94 pin connector)
Thanks 😁
