fault found: B11A5 11 [008]
Hi all,
Octavia III 2.0 CRM 110KW, 2015. Occasionally after turning the key in the first position (sometimes even after the engine has been running for approx. 5 minutes of driving), a yellow key error appears: Faulty starting system. To the service!
After about 15 sec disappears, the cycle is repeated 2 to 5 times and then calm. The engine normally starts, runs fine....   The error occurs even when I using the second key ...
Address 09: Cent. Elect. (J519)
1 Fault Found:
135432 - Terminal S
          B11A5 11 [008] - Short to Ground
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 16
                    Reset counter: 208
                    Mileage: 184529 km
                    Date: 2019.07.30
                    Time: 18:41:43
.... some ideas where to look...
  • 4 years later...
Hi @uda10
Did you manage to get this fixed? I am getting the same error on a Superb III, 2.0 TDI 150HP.
The battery sensor located on top of the battery as allready been replaced.
