Deleting
How do you delete a inaccurate post by myself
Edited by Channel
Inaccurate
Next to Quote/Edit there should be Options, click on it and it says " Hide "  You can hide a post but if you need to delete  a thread  it's a Moderators Job.
Edited by Auric Goldfinger
I think you need to be a Freedom member.  Then you can delete a thread if you are the OP.
I will alert a Mod.
Edited by Roottootemoot
all i do is delete   put a !
If you are not a Freedom member the time is limited in which you can edit to do that.
If you click on the 'Share this post' icon which is similar to a < on the right of of each of your posts and then PM me the details I'll sort it.
Other than that and as others have said, if you're a Freedom member you have an unlimited amount of time to be able to alter your posts. :thumbup:
