1.2TDI erratic engine behaviour and fault codes
Hi,re
Our 2011 Fabia Greenline II 1.2TDI just started behaving erratically - fortunately my wife was close to home and just got back. It starts up OK but then usually runs with  sudden very short dips in revs usually accompanied by a harse knock (a bit like pinking) randomly every few seconds. It happens at different engine speeds. Initially there were a few fault codes P2452 P0401, P060C, P0641,and pending faults  P2015, P046C
Other odd symptoms were once after starting the engine the engine idled, but the rev counter went to maximum and stayed there. Another time it started but the starter motor continued running. Occasionally it would idle but there was no response to the throttle.
I went through a few cycles of resetting the codes and turning the ignition on and rescanning. Sometimes no codes came back and other times several pending faults usually one of those listed above (I can't remember exactly). At one point P0641 (5V sensor reference A open) and P060C were coming on as active faults, the latter being the most worrying. I only have a cheap ALDI code reader so I'll try to borrow a good one from a mechanic I know to seee if it gives some more info, but I'm not sure what to look for.
I started removing sensor connectors on the engine; 5V was present on them all and seemed solid when the engine was running - but I was using a slow DVM so I might try monitoring with an oscilloscope to see if there are any short dropouts. Since then P060 hasn't recurred but P0641 does. In case a faulty sensor was briefly shorting the 5V, I tried removing all the connectors on the engine that still allowed the engine to run (DP pressure, EGR pressure, EGR valve etc.) It made no difference to the erratic running.
I'm wondering if the crank position sensor may be faulty - it could account for the sharp knocks if it injects at the wrong time, but there aren't any associated fault codes. I hope it isn't the ECU, but its a concern given the odd range of fault codes. Last few times I tried I'm got a P2245 - turbo wastegate solenoid a low? However I guess that if something is intermittently dragging the reference down then the ECU could detect it on any of the sensors.
Any ideas? would it be worth replacing the crank position sensor anyway given it doesn't seem expensive at around £10?
With code P0641, should there always be another fault code indicating which sensor it got a bad reading?
Welcome to the forum, hopefully someone that knows stuff will be along to help.
Sorry, not any help, but has your car had the Emissions Fix and when?
No way was I going to allow the 'fix' after reading of the dire consequences. Funnily enough my mechanic colleage asked me the same question today; turns out his sister had her Audi's emissions 'fixed' not long ago and suffered an EGR fault on the way home. Audi refused to replace the EGR claiming it was nothing to do with the update - long after VW had rescinded and were offering free EGR replacements for a limite period after the emissions update.
Same situation here, EGR packed up less than a week after the 'fix'.
On topic, have you got access to anyone with a VCDS? It will give you a bit more insight on what's going on, and would be much more specific than OBD.
If you don't have a look at the VCDS map, there will be someone who can loan you one.
I will try and help as best I can from my experiences as I too have the 1.2 tdi greenline 2012 model. However on mine the EGR valve had to be replaced before the assumed 'fix' because the dealer could not carry out the 'update' as this part was faulty. I say update because I have been told by the dealer network the this update was never completed properly for reasons I'am trying to find out but will get the answer.  But it really does prove that EGR faults can occur if the vehicle has not had the service campaign yet.
With regards to idling issues this could be vacuum or air leak. Mine sometimes does this but I believe this could be to do with the inlet manifold cracked. Check all pipe work especially the ones that come from the valve and run along the air filter box to the engine elbows and 'T' pieces. Also check condition of the turbo / intercooled pipe work. ( any oil misting tighten clamps if required). Also check condition on vac pipe and pipe work on the EGR valve itself.  Does your vehicle hunt sometimes? When idling watch the stepper motor which operate the swirl flaps on the intake manifold. Is it constantly adjusting? Look closely where the spindle is. Any weeping oil coming from there? As you know any leaks even if tiny will affect the running of any diesel as it will draw in air and that ecu will adjust parameters. I know it's tidious but it's best to check the simple things first.
Electrical gremlins. Ok check all earth strap points in engine bay clean tighten and protect. Check condition of fuses and wiring on top of the battery again check connection security clean off any corrosion if any. Is the battery original? Is it getting past its best? Give it a treat and trickle charge it see if makes any difference.
Do do you use the stop start feature? Bearing in mind this might be a good idea but this can cause heavy loads on the battery and starter motor and the solenoid could be packing up. Not sure how many modern cars nowadays need frequent starter motor replacement. I turn off this feature on mine as I don't like it being an old school driver. Anyway check for chaffing of the wiring loom near the alternator as some models under warranty had to have a section changed and re-routed away from the engine block due to rubbing. Check crank sensor wiring is clipped in properly along its route they tend to work loose. It's really near moving parts in my view.
Instrument panel gremlins could be can bus issues or low voltage issues. As you know low voltage can cause havoc with some modules. When turning over it could be drawing a lot of current causing dips and spikes in different areas of electronics.
EGR/DPF codes. Does your vehicle regen properly? Is she in limp mode? Any mil lamp on? Or are these pending on code read? Try this if possible. Put some super grade diesel in. Grab a can of any DPF cleaner or cata clean. Take it for a good half hour run. Don't be worried about giving it a little throttle. Get that exhaust hot. EGR valve could be getting a bit coked up. If you can while on the drive keep clearing down the codes. See what happens. I have picked up many diesels vehicles in the past and if I see black smoke when I gun it this is the EGR clearing out. After a few runs like that there is no smoke. These need to be kept open so they don't choke up. On mine I do try and keep treatments regular.
Silly question how often does the diesel filter get changed? I have learnt that since owning this model regen process degrades the oil very heavily and I now get it changed even 5k.
As you already know that if one fault occurs it's usually linked to others however I believe if one system is not functioning properly the ecu decided to shut down some others for example regen is stopped if this occurs then the EGR system is shut down until the fault is rectified and to stop engine damage.
If if you live close then I would be willing to help you using my diagnostics system. Just so you can get some clarification on these faults. This is just advice and I may not be correct on everything but this is what I have come across on my vehicle and hope this helps you as I'am constantly checking mine with the same engine but keep it simple first.
Best wishes A
Thanks for the responses and possible lines of investigations.  The fault codes kept changing,  but at one point it was consistently bringing up P060C (ECU Fault) and P0641(sensor reference A open Circuit).  I took it to an independent garage today and they came to the same conclusion as me that it is an intermittent ECU fault. At one point during investigation one of the sensor reference lines went to 9V for 30 minutes - perhaps an ECU fault but maybe caused by a short in the wiring to a 12V signal so not conclusive.
At the end of investigations they hadn't knowingly fixed any problem but cleared the fault codes and now it's working OK - probably not for long. Maybe disconnecting the ECU disturbed the wiring causing the fault to go away for the time being but I expect it will return.  I'll have to have a good look at the wiring when I get a chance.
I talked to an ECU repair company; apparently the Delphi unit I have is Copyrighted and dealer only. The engineer who investigated the car today said Delphi units are a problem and difficult to deal with.  He also said they're potted inside making repair extremely difficult.  He wasn't sure that you can fit a second hand unit and get the immobilizer to work with it - with older ones you could recover the pin codes to enable reprogramming the ECU to work with the existing console/immobilizer/keys or at worst you'd disable the immobilizer to get you going but not with the more recent units. Perhaps that's why there are some very cheap (£20 is)  ECUs on EBay as they are useless? Hopefully there are some specialists out there who can deal with these.
A new ECU is £1200+ which would write the car off as even if I decided to cough up the money,  the new unit would presumably come with the 'emissions fix' with a good chance of requiring new EGRs every year or two and possibly DPFs and injectors.  Not worth the risk.  Even if you can get a cheap second hand unit to work it may well have had the fix? How could you find out before you bought it?
This Skoda has been the least reliable car I've ever owned, and that's coming from someone who used to own a Montego!
  • 2 years later...
Hello friends!
Splin how the story ends? I have same
problem 🤔
BestRegards
Dude, thread is three years old, start a new thread accurately describing your problems.
Splin's not been to this site since October 2019, with only 3 post in the 15 days before that it is doubtful they look at the site now, so as suggested best to start a fresh thread of your own giving as much detail as possible and bear in mind no information from here will be on your thread, at least not initially.
He already did, do keep up dear!
And it was the thread I saw just before this one!  Oh dear, my dear, good job you're 'ere.
It didn't gauge in my razor sharp computer like brain as the title was slightly different, must have been that last update in 1982 that messed things up.
