Window issue is tilting me!
Hi everyone!
I've bought a 2007 Octavia RS 2.0 TFSI, which I've wanted for a really long time. The car was in very good condition, with the exception being a few minor but annoying issues.
1. The left rear window shuts/opens the other way around, no matter if I'm doing it from the driver's seat or directly on the rear door button.
2. Rear left window frequently opens (even when car parked) when it rains - I just read somewhere that there might be a connection between the rain sensor (which I usually leave ON) and this issue. I'll test.
3. The Window washer pump is not working (front or back). I've had a look but could't manage to see where it is to check if it could have become disconnected (powered off) or faulty. When I pull the stalk to activate it I can't hear any sound coming from the bonnet. Has anyone replaced one of these - what do I need to disassemble in order to get access to it?
4. Weird hissing noise somehow associated with the brakes. The sound is just like a leaking air pipe. I can hear it whether or not I'm moving. When I press the brake pedal I hear it stop and it resumes the moment I take the foot off the brake.
@cris_bugio
  1. Well, this car has CANBus electrics, so this sounds like a software issue.
  2. As (1)
  3. Since you're not hearing the pump, are the wipers operating? If they are, the issue may be a failed pump, which is located on the washer tank.
  4. Vacuum leak? Do the brakes require more effort than other cars you've driven?
1/2. I've ordered an ODB2 reader but unfortunately it seems too big around the edges of the plug to fit and provide connection. I'll try to get an extension cable, or another reader... I'll update once I manage to get a proper reading.
3. The wipers are operating, it's just the water that's not coming out. I've tried having a look but thus far nothing resembles the parts I see for sale online. I can't seem to see the bottom of the tank though. Do I need to remove anything in order to gain access?
4. The breaks are more sensitive and powerful than any other car I've driven so far. Although in the last few years I've just been driving crappy cars... LOL This is my first "performance car".
  • 3 years later...
Just a follow up, as I've been working on the car recently.
These were all fixed (eventually) at the dealership. Washer bottle replaced, washer pump replaced, one of the windows was connected the other way around somehow... also fixed a blockage on the sunroof where it would somehow leak into the cabin when it rains heavily - the chaps at Skoda reportedly used a pipecleaner to unblock the pipes that come down the pillars.
Recently dealing with a P0299, which I beleive I fixed (not coming up since) by replacing the air intake with a Ramair intake.
Next repair is going to be related to a P0441 EVAP fault - bough myself a carbon canister and N80 valve to replace - I'm over 240.000km now, so it's probably due to replace anyway.
...the brake hissing seems to be gone after the last couple of visits to Skoda. 😄
