DPF Issue on Octavia CR TDI (Remapped)
Hi All,
Bought my first Octavia vRS CR TDI 170 2 weeks ago private sale.
I bought it as I had previously had a Fabia vRS 1.9PD which was brilliant and had rarely had any issues. However ...
The guy I purchased it off had an issue with DPF so it took it to garage who said its going to cost at least £900.
He spoke to a mate who said to get the DPF removed and remapped to avoid light showing on dash.
He had this done recently and then sold the car. When I picked it up it had no lights on dash and run perfectly fine. He even said give it some revs to test out the remap and it had all skoda stamps in history and had flywheel/clutch/service completed recently etc
After a few days the DPF light came on but performance was unaffected.
Then the week after I was driving on motorway and the revs dropped (I suspect an overboost situation form what i've read  - however there was only me in the car) and the car went into a limp mode but no lights other than DPF remained on the dash.
I've got Ross Tech VCDS so plugged that in and came up with only 3 errors (2 for electric windows / 1 for Climate Control) I saved the file and cleared those DTC's and they haven't come back but the DPF light remains on.
If the DPF has been removed and the cars been remapped why would the light come on and the car go into limp mode? - I've spoken with previous owner and he's going to check with the guy who remapped it as they said it wouldn't ever come on after remap but I suppose it sold as seen so don't expect him to chase.
Do I have to force a regen on VCDS in order to trick the car somehow?
I've read this could be the Turbo Vanes sticking as well as the actuator or possibly the EGR valve ? ( have people used Mr Muscle oven cleaner from what i've read also)
Do these need cleaning maybe taking apart?
Or could it be a sensor of some sort?
The car to drive was spot on before this and now driving to work with no turbo is frustrating.
I just don't know which avenue to take first.
Cheers in advance.
Not much help but it sounds like the DPF is very much still there!
Not sure i would want to purchase a car with a DPF chopped out as that’s now an MOT failure.
Have you checked the obvious hoses under the bonnet to check nothing is loose?
I too am suspecting this.. Has the previous owner supplied any proof of this being done?
I haven't heard of anyone having the DPF light come on after it's been deleted and coded out..
Might be a good idea to visually verify the delete and make sure it was actually done.
If you still have access to the VCDS you could check what the car says about current DPF capacity etc.
I think there should have been some warning belts when the seller said it had the DPF removed (MOT fail) and was selling it despite it having had the DPF removed recently. That very much feels like a car with potentially expensive issues they are trying to shift. Happy to be wrong though!
At this point it feels like the DPF either hasn't been removed, removed badly or something completely unrelated 😕
Either way, warning lights should almost always have an error code stored:
- Can you post a full autoscan from VCDS?
- Can you also add a picture of the dash to confirm which light it lit?
Thanks everyone ... the saga continues ... I managed to plug Ross techs VCDS in and tried following the Regen process.
soot level - 44.7% (so unable to complete a regen while idle - issue is if gets past 45% not sure if vcds will allow forced regen)
managed to get coolant temp upto 70 (just)
the turbo temp was 156 however there were no temps showing for before DPF or after DPF for the temp sensors (I surmised these have been deleted off the ecu following remap/removal of DPF?)
So went to complete a driving Regen and follow the instructions but vcds wont accept the 12233 code (shows an error) for engine (will only accept the idle Regen code - tried this but that aborted)
spoke with previous owner who said it’s definitely been removed and remapped but with reading up I’m starting to think it wasn’t remapped correctly to take account of the DPF warnings that would come up.
Ross Tech have asked for a full scan so will provide that to them and on here an take it from there ... only 3 faults come up when I’ve done it on autoscan which are left & right windows and HVAC which I think is air con (I read somewhere that all codes need to be deleted before Regen can take place though?)
so much info knocking around on here and Ross tech site but better to have that than none as it helps to diagnose faults quicker.
Will provide full scan in a bit with picture of amber DPF light.
thanks everyone so far who is helping with this issue.
Appreciate the help 👌👍
In which case, there is no way the car can perform a regen - it needs the extra temperature information.
Do you mean % or g? The maximum soot loading if 45g before the DPF needs to be replaced. No tool can force a regen at the stage. There is a chance this is just a side effect of however the DPF delete was performed.
At this point I think you're choices are either:
- Have the engine software returned to stock, then replace/refit the DPF any anything else that's been messed with
- Take it to a decent tuner and have them start from scratch with a known good DPF delete and a map of your choice
Given you're in Wakefield, it might be work giving Darkside over in Barnsley a ring as I've heard good things about them. If nothing else, they might be able to take a look and suggest some next steps.
thanks langers2k. I suspect if nothing can be done by ross tech via vcds with not having correct conditions in place its a remap job again or get under car and see exactly I've actually got attached to this engine.
I've only just registered on Ross Tech and awaiting approval so will post the autoscan on here …
Wednesday,23,October,2019,11:25:19:08728
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: TMBEH21Z0A2075276   License Plate:
Chassis Type: 1Z-SK35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBEH21Z0A2075276   Mileage: 242090km-150427miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CEG)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 RD    HW: 03L 906 022 GA
   Component: R4 2.0l TDI G000SG  9977
   Revision: 13H03---    Serial number:
   Coding: 0001072
   Shop #: WSC 57307 001 1048576
   VCID: 78A9EAA96ED16A47F17-802C
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 163B601C092900FF680D06EB901F0082340800
   Shop #: WSC 73430 790 00999
   VCID: 78A9EAA962D16A47F17-802C
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 3T0 907 044 AR    HW: 3T0 907 044 AR
   Component: Climatronic   H15 0401
   Revision: 00005001
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01006
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 025D8841348D3097DF3-8056
2 Faults Found:
13701888 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Motorsteuergerät - bitte Fehlerspeicher auslesen]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 9
                    Reset counter: 249
                    Mileage: 241915 km
                    Date: 2019.10.20
                    Time: 21:26:07
9479185 - Signal Line for Air Quality Sensor
          B10A4 11 [009] - Short to Ground
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 9
                    Reset counter: 209
                    Mileage: 241915 km
                    Date: 2019.10.20
                    Time: 21:13:50
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 D    HW: 1K0 937 087 D
   Component: BCM PQ35  H   103 0575
   Revision: 00103 AG
   Coding: 48180AB8B05BB1C040080080110001E4430000AE424D8160800440040000
   VCID: 323D1881C42D40170F3-8066
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 08120  22  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 3 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
Address 10: Park/Steer Assist (J446)       Labels:. 1Z0-919-475-V1.clb
   Part No SW: 1Z0 919 475 B    HW: 1Z0 919 475
   Component: PARKHILFE 4K  H06 0006
   Revision: --------    Serial number: 66640934101263
   Coding: 100002
   VCID: 40D942497A81E287897-8014
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2HKM5T
   Coding: 0020788
   VCID: 3D273BBD01738F6FE21-8068
   Subsystem 1 - Serial number: 6332MSME4D65422FM
   Subsystem 2 - Serial number: 6342MSME4E140638C
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000034
   VCID: 03538D452717399FD45-8056
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 1Z0 920 903 J    HW: 1Z0 920 903 J
   Component: KOMBI         H06 0305
   Serial number: 00000000000000
   Coding: 410B00
   Shop #: WSC 73430 031 00999
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
   VCID: 3C2136B916E98667D5F-8068
Address 19: CAN Gateway        Labels:. 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4520K09C100553
   Coding: E9A07F06000202001303
   VCID: 698FBFED257BC3CF7E9-803C
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H06 0305
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC0E12CFDC8D7773-803E
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2114
   Coding: 0000756
   VCID: 48C95A695EB1DAC7417-801C
1 Fault Found:
00109 - Left Mirror Turn Signal Lamp (L131)
            012 - Electrical Fault in Circuit
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 69     3305
   Revision: 00H22000
   Shop #: WSC 35115 000 1048576
   VCID: 372B2995234FA53F38D-8062
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000756
   VCID: 47CB595553AFD5BF48D-8012
1 Fault Found:
00110 - Right Mirror Turn Signal Lamp (L132)
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
   Component: BOLERO        008 0053
   Revision: 0A001001    Serial number: SKZ1Z3I8181272
   Coding: 0D0004000001
   VCID: 3537239D3543572F2A1-8060
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 73430 790 1012551
   VCID: 323D1881C82D40170F3-8066
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 33331D853737491F045-8066
End----(Elapsed Time: 01:01, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
Apart from the battery being a little low, there isn't much there to go on. There are no faults or any other reason for the DPF light to be on so the DPF delete is very suspect at this point. I doubt VCDS is going to help given that...
The ECU software version is 9977 which means it's had the 'emissions fix' applied at some point. I would have expected a decent DPF delete to have also rolled back the SW to a previous 'unfixed' version, even more so as 5751 has previously been released for your ECU.
Thanks langers2k appreciate your support.
i contacted Darkside and they sounded great only problem is the price and not willing to entertain figures of £450 plus for remapping vs what I paid for the car.
Anyone know of a decent remapper who is cheaper but will compete the DPF Delete correctly ?
Thanks in advance.
You could try AmD, Bigfishtuning, Revo or Racingline (previously Shark or bought Shark)?
I'd expect them all to charge a similar amount though :/
Thanks in advance.
The low-budget option would be to get a mate to cut the DPF out of the downpipe and replace it with a pipe, then get it towed to a tuner who tune it out. However, I presume that since its not the easiest thing to fabricate it would cost nearly as much to do.
Thanks Langers2K and Marfrohun 👍
i read on here about might also be the exhaust pressure sensor but having looked I do already have the revised “made in Malaysia” one fitted so suspect it can’t be that and looked at the other tuners you suggested and they are miles away so Darkside best option for tuning by looks of it.
just so frustrating buying a car you bought as a run around to go then spend 20% of cars value on another remap to sort out a bloody light which shouldnt come on when DPF is removed.
Im basically paying £450 to have an error light removed off dash which vcds should do because it put the car in limp mode 🤣
do these made in Malaysia sensors go faulty ? I’m wondering where if I try that I could get the soot levels down to then calibrate the DPF via vcds but only problem I have is there were no readings on the modules in vcds for before and after DPF (with it been removed and having a straight thru pipe) wondered whether we that’s been deleted partly out.
If it had stock software on the ECU, there would be a fault code which VCDS could clear - the problem is the software has been messed with and is hiding the problem from you. Given it's had a DPF delete, the DPF innards should have already been removed so there is no soot to burn off... :/
Until you're able to find out what's causing the error light, there's not much point swapping sensors or trying to adapt a missing DPF.
Do you know who did the original DPF delete? If they are even half decent, I'd hope they'd be willing to take a look at a reasonable price rather than a full map + DPF/EGR delete price.
Thanks Langers2k (I do appreciate ur feedback)
the remapper is a good 2 hours away from me and the previous owner said It sounds like he’s done it wrong and wouldn’t want to use again but has found another remapper who could do it cheap but again it’s same distance.
ive found on VCDS the module for soot level and the rising figure which maybe causing the car to go in limp mode with light on dash.
i have 3 figures :
Particle Filter Oil Ash Volume
-0
Particle Filter Carbon Mass (spec.) - 48
Particle Filter Carbon Mass (act.) - 0
i suspect what I need is to get the particle filter carbon mass (spec) deleted off the ecu.
i spoke with Darkside again and it gets worse ... I know they are valued as great remappers and I get it but I’ve bought a cheaper alternative to my golf R as a cheaper runaround with the miles I do and they want £70 for diagnostics, £480 for remap and if it needs an EGR kit another £100 ... it’s just not viable for what I paid for the car.
Before I look at buying a standard DPF and fitting it and trying to get a stock remap fitted back to its normal 170bhp.
does anyone know of anyone who would be willing to work with us on trying to delete this carbon mass figure out of the DPF?
it seems bonkers trying to throw £650 on a 150k miler work runaround for a light on a dash for a figure which is speculating the carbon mass.
thanks
My car has done 146k and I personally wouldn’t be happy paying that much to sort out what seems like a simple plug and play issue however I can’t see returning it to standard being anymore cost effective.
If your prepared to travel why not search for another tuner although arguably once you factor in fuel Costs you may not be far off that higher figure anyway?
All tuning work on these cars seems relatively expensive (£350-450) compared to older engine generations. I would have expected the price to start coming down by now given their getting older but it hasn't.
Your options seem pretty clear but I don't think there is a cheap/easy direction for you 😞
- Spend most a day driving to see the original or seller recommended mapper can fix this.
- Use a reputable mapper but pay extra for proven software and their experience.
- Refit the DPF and flash the stock software. A good condition DPF will probably be £500-1000 alone...
With all three options, it should just be a software flash and obvious fitting a DPF if returning to stock. There is also a chance their are other issues currently being hidden by the bad ECU software but it's impossible to see these until you've taken the first step. I know these aren't the answers you're looking for but I can't imagine an alternative.
Who was the original mapper and who did the seller recommend? Just curious as it might be worth seeing how well reviewed regarded they are.
