estate rear springs
looking at doing a rear end refresh on my combi, it has towed in a former life and is a little saggy. will be using a pair of bilstein b6 shocks but what springs are best? are genuine suitable?
I am going to fit the Bilstein springs which go with my B6 rear shocks when it comes time to change mine. Normally I would only ever fit genuine parts, but Ive seen too many broken road springs let go.
This spring will match my setup: 2012 3T5 170CR 4x4
https://www.bilsteinsuspensionstore.co.uk/bilstein-b3-spring-36148257_p31023825.htm
Prices are each
Edited by 3T51704x4
@rover220
I would stay away from O.E. springs
My car is on the 4th pair of rears
First 3 being O.E.
Originals it came with were replaced at 55,000 under warranty
Second pair under extended warranty when I got it.
3rd I bought a full set that only had 6,000 miles as the guy had replaced full suspension to B12
I coated these with a light grade underseal paint to try and see if they would last longer🙄
The paint lasted longer but the  springs still broke at about 50,000
Edited by DEL80Y
On 24/10/2019 at 20:36, DEL80Y said:
@rover220
First 3 being O.E.
hi, i went away from oem set up and i fitted bilstain b12 kit, car is 30mm lower  compered to standard but I can load it boot now without worrying about speed bumps.
