Octavia large mph display help
Looking for someone who will activate the large speed display on my 2010 octavia with vcds. I am southwest in Gloucester but happy to travel
I can't seem to see anyone on the map. It brings up the map which is blank
Odd...
Closest on the map to Gloucester is @superbdreams :)
Here and able 😀
I can't message you but would be grateful if you could. Give you some beer money for your trouble
23 hours ago, Mjr001 said:
I can't message you
you have and i have replied.
Many thanks superbdreams for activating this today for me. Top guy
Which option is it in VCDS for large mph display?
I believe it was control modules then instruments to change the country code to Australia
I tried this and the digital speedo was still in km/h, and the odometer also changed to kilometres
You have to change the units in MFD to miles
OK I did this too, the mpg and odometer are now in miles but the digital speed display is still in km/h. There are no settings to change it from what I can see
Follow this walkthrough (ALL of it)
Thanks I figured it out, I assumed the "alternate speed display" would show MPH after changing the country setting to Australia. But actually I had to uncheck that setting and enable the Digital Speed in MFD data. Works beautifully now!
Correct, the alternative is the KPH display. 👍
