Auxiliary heating problem
I have problem with my heater.
When trying to start it with the remote it flashes  fast, indicating that something is wrong.
On the dashboard it says “Problem: auxiliary heating”.
The car is a Skoda Superb 4x4 2.0 tdi.
Anyone suggestions?
What are the most common fault with these heaters?
BR
To suggest anything would be a guess at this point, if you are capable I would scan it for codes first, then take a look at it and check the most common things like any connections on the unit, check fuses, check the glow plug resistance is in spec etc.
I had a similar problem recently on a 3.6 SII Combi.
I remotely started it in the morning, then drove to the airport
When the car parked, I switched on the ignition and had the dreaded error message on the maxidot
Trying to activate it both manually with the switch on the climatronic as well as the remote did not work,
error message and blinking light.
The error logs seemed to indicate something wrong with the unit as you can read below
The unit got locked.
But after disconnecting the battery to work on the car for a few hours.
Battery reconnected , it just works.
================ snip snip ============
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 5K0 963 272 F
Component: Standheizer 022 4008
Revision: 00022000 Serial number: 09029167000000
Coding: 0021112
Shop #: WSC 23370 002 1048576
VCID: 3332EBBC173692AF07B-8066
2 Faults Found:
01406 - No Flame
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 10
Reset counter: 254
Mileage: 123184 km
Time Indication: 0
Date: 2019.09.16
Time: 08:50:50
Freeze Frame:
Start
Temperature: 64.0°C
Temperature: 42.0°C
02251 - Heater Unit Locked
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 214
Mileage: 124990 km
Time Indication: 0
Date: 2019.10.30
Time: 05:20:26
So maybe it will also work in your case
Can you post your logs ?
 L.
Thx for the information!
I read out the fault code today, see picture below.
It says in Swedish that the circulation pump is overheated, so most probably I need to change that one.
Most likely it will start if I disconnect/connect battery, but will probably fail after a while.
Planning to change the circulation pump myself.
Have anybody any advise to give?
Is it difficult?
BR
Today I replaced the cirkulation pump, it was no problem.
Disconnected the battery (for 2h) to get rid of the fault codes.
But after connecting the battery again still the same problem.
Does anybody know if I need a computer to unlock the heater?
Or should it be enough to disconnect the battery?
Really appreciate all help.
BR
Fredrik
from the VCDS documentation there are procedures to unlock the heater on other cars.
But as it is the device itself, my guess it would be applicable to the Superb also
http://wiki.ross-tech.com/wiki/index.php/02251
as well as other threads.
https://forums.ross-tech.com/showthread.php?13886-Skoda-Octavia-MQB-unlocking-aux-heater
https://blog.lausdahl.com/2011/12/unlocking-webasto-aux-heater-on-a-vw-touran/
On my side, got lucky, battery disconnected did unlock it (or maybe they did some VCDS coding on it without me knowing it)
When you manage to unlock it, please let the Superb II community know about it, would be really grateful
 L.
