Karoq sat nav
Having a new 2.0 SEL 4x4 Karoq with Sat Nav and read most of the manual  I cannot find anywhere, the method  which allows you to look at the whole route with all the turns and junctions like you can on a Garmin or TomTom.  For example, if a destination has two methods of getting there how do you know which route it is going to take when all you can see are the first three turns.  Where as on the  both Garmin and TomTom you can see the whole route and where you are going to end up, which is particularly useful if using a post code which in some cases can be quite a way from where you wish to be.
Zoom out?
tom
Press the view symbol at the bottom of the screen, get the option to see finish  or the whole route .
Yes  that is fine.  But it does not give you actual turns and the road used, such as (494 in two miles turn onto the M56 ) for the whole journey only the next three maneuvers.
To see the whole route use the right side control knob to zoom out. You need to specify which type of route you want in settings. Faster will force you onto motorways although it may be a longer distance. Add a waypoint as a stop to force it to calculate a route you favour.
My ancient portable Garmin which cost £78  is better than the Amundsen and shows photo images of the carriageway for upcoming lane changes. (Saved my bacon in peak hour bypassing Madrid around the airport). Tap the top of the screen and it lists all the turns and distances to them. The voice commands give faster advance warning too. Amundsen has only three points of interest. There are far better plug in satnavs available, Aldi even  does one for £35.
Plus Skoda maps are not updated. Latest ones, released just week ago, are YEAR old Here Maps!!!
