Battery failure in Keyfob
My 2015 car does not have KESSY, and, from what I have read about it, it seems to be more trouble than it's worth. Recently I got the change key battery message and changed the battery accordingly. I have owned the car from nearly new, and this is the first time that I have had to change a key battery, with the car now being almost exactly five years old.
Not knowing what condition the other key battery was in I decided to fit a new battery in the spare key and transfer the old battery from the spare to the key that I always use. I now feel confident that the battery in the spare key is OK, and should get a message when I need to replace the one in the usual key.
I also replaced the shell of the key, as the old one was starting to disintegrate on the side where the buttons are. I find this a bit surprising, as the keys of my old 2007 Octavia are still intact after 13 years.
  • Replies 55
  • Views 17.3k
  • Finally some good news for long suffering Karoq owners when I collected our near 2 year old Karoq 1.5TSi SEL with 22,800 miles on the clock after 2 days at the Dealership they have confirmed both of o
  • I suggest that a better way of letting Skoda know of this is a complaint on Skoda web site, fill in the web form. Certainly mention it to the dealer, but they will likely not pass it back to Skoda. If
  • A way to tell if the battery is going flat is that the red LED on the key fob will stop working when pressing the buttons or using KESSY but the car will still open and start the car until the battery
As a minor aside, anyone know the battery type for the pauper spec “standard” key, the one where you have to press a button to lock or unlock the door?  The manual just says “the battery” and doesn’t specify the type.
Edited by DSL
Unless things have changed in recent months it’ll be a 2025 as fitted across the VW range for many years.
However, I doubt you’ll be troubled in the near future by a battery change as a 10 year battery life is not uncommon In those fobs.
Many thanks, that’s good to know.
The battery which I just replaced at 5 years old was that type. Not so impressed with the life of the fob having just replaced its shell. Maybe it has suffered from spending a lot of time in my trouser pocket, as I always like to keep my keys with me. Occasionally I have found all the car windows open which I think is due to the unlock button getting pressed accidentally. I have now got a small Faraday pouch for the key which should solve this problem and maybe give the key some extra protection.
I too always keep the keyfob in the trouser pocket, together with house keys and change. So my wife has sewn a custom pouch made of thin leather. The keyfob never leaves the pouch, as the Kessy function works unhindered and I can locate the right button through the thin leather when I need it (to temporarily disable Kessy or to open all four windows).
Keyfob like new after 16 months.
