Yaw Rate Sensor location
Anyone knows the location of the Yaw Rate Sensor (G202) in Yeti 2012 Elegance 4x4? I had been getting this Stabilization Control error and VCDS scan is pointing to fault in Yaw Rate Sensor.
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 933F400E092201FBC91102EB901B808A350C00
Shop #: WSC 73430 790 00999
VCID: 7BF51167FA10BBC6C11-802E
1 Fault Found:
01542 - Yaw Rate Sensor (G202)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 164
Mileage: 68868 km
Time Indication: 0
Date: 2016.14.14
Time: 11:10:10
It's inside the ABS pump electronic control module.
It might be possible to open it and fix it but it's probably easier to replace it with a good used module.
My technician already had a looked at the ABS module and didn't find one. I guess its different from Octavia.
Yes, that's because it's inside the ABS module. It'll be a component on the PCB and not designed to be replaced separately.
The older MK60 ABS pumps had a separate set of sensors that were normally under the front seats. This changed when the MK60EC1 was released, the sensors are now inside the ABS module. This will be the same for any car with 1K0 907 379 BJ fitted...
  • 3 years later...
Hi @langers2k @bahrur
I own an Indian Right hand drive variant of Skoda yeti 2011 elegance 4x4 model and I am facing a similar issue.
the OBDeleven scan returns 01542 yaw rate sensor error.
I could not find the location the yaw rate/rotation rate sensor on my vehicle.
My vehicle is fitted with the the abs pump: 1k0 614 517 DC.
Please help me find the location of the sensor in my vehicle.
